My House - Ideas For Addition
Old 02-27-2009, 03:53 PM   #1
Dufus Extrodinaire
BHR's Avatar
I'm stumped. I am planning on putting an addition on the front of my house but can't seem to find a concept that I like. Been searching images but no roof lines like mine with the same type of house build. I've been driving all over hoping to see something but, nada!
The thing that's got me is how can I incorporate a nice front with say a 10/12 pitch (gable) to the roof line that is presently there.
The addition will be a masterbedroom w/ ensuite bath - with a garage below (side access). Starting from the right of the front door to the right end of the house. (26'x16'). And the front entrance moved out 10' - so 7'x10'. Brick on all.
I've been drawing and drawing but to no avail...I am not a house builder - I am interiors.
I will be getting an archy in a couple months for plans but I would like a concept of some sorts so I can think a bit clearer.
Much appreciated guys!
BHR is offline
The Following User Says Thank You to BHR For This Useful Post:
idiotfromPA (02-27-2009)
Old 02-27-2009, 04:00 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Re: My House - Ideas For Addition
Tri-levels are hard to deal with, hard to make something new look right with that style of house.
WarnerConstInc. is online now
Old 02-27-2009, 04:11 PM   #3
Professional Instigator
rbsremodeling's Avatar
You build the roof line of the new addition higher than the old one and don't tie in to the existing roof.
rbsremodeling is offline
Old 02-27-2009, 04:13 PM   #4
Dufus Extrodinaire
BHR's Avatar
Sorry, I should have said it was a raised ranch. Lower level is at grade with the driveway - upper level is one floor. The area for the addition will be dug out to accomadate the garage
BHR is offline
Old 02-27-2009, 04:56 PM   #5
Joe Carola's Avatar
Trade: Framing Contractor
Here's a very bad quick drawing. Is this something like what you're talking about?
Joe Carola
Joe Carola is offline
Old 02-27-2009, 05:06 PM   #6
jmic's Avatar
Think about deleting the roof over front entryway and carrying rafter tails down from roof that Joe C. drew on the addition to cover entryway.
Joe
jmic is offline
Old 02-27-2009, 05:36 PM   #7
Dufus Extrodinaire
BHR's Avatar
Thanks Joe. Yeah sort of like that but the door is at the upper grade level and the foyer is moved out 10' (enclosed)
This is what I had come up with but it's all wrong and i know it by looking at the roofline sketch.
i was hoping to keep the additions roofline at the same height as the exsisting roof. - likely won't happen right?
BHR is offline
Old 02-27-2009, 05:49 PM   #8
Joe Carola's Avatar
I raised it so that the fascia meets the top fascia and you will just have to frame a cricket on top where the entrance roof gable dies into the main roof gable.
Joe Carola
Old 02-27-2009, 06:46 PM   #9
I like Green things
Run the back side of new roof past old, match over hangs and put a vent in that little tiangle. I added a new roof system on a really screwed up house layout and that is pretty much what I had to do. You could always hip the new roof section back into the old, and hip your front stoop and then make a cricket to funnel water out and down.
Old 02-27-2009, 07:38 PM   #10
Dufus Extrodinaire
BHR's Avatar
I had thought about running the new roof all the way to the back but thought it may look odd. I never thought about being able to hip the gabled roof to the old or even doing a hip on the foyer roof.
thanks so much
I just need a good compromies for the front since the front wall is so tall due to the grade. I sure would like to be able to do a gable since the wife would like a vaulted type ceiling in the bedroom.
BHR is offline
Old 02-27-2009, 08:51 PM   #11
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
Well frankly speaking, if you start putting differing roof pitches in there willy-nilly it will always look like an after thought. Keep the same pitch on the addition as is on the main house. If need be put a differing pitch on the entrance, it is smaller and would benefit from a little added flair and dimension.
Keep the existing semi-garrison look with the upper siding and the lower stone, at least somewhat.
Spend a little money and hire a good residential designer. We can do your design and your construction documents.
Andy.
ScipioAfricanus is offline
Old 02-27-2009, 08:58 PM   #12
General Contractor
greg24k's Avatar
Did this a while back.
My House - Ideas for addition-addition_level_before__web_.jpg   My House - Ideas for addition-addition_level_after__web_.jpg
greg24k is online now
Old 02-27-2009, 09:32 PM   #13
oldfrt's Avatar
I think I would try and build a hipped roof on that addition to make it look like it was built with the original house.
You could get a vaulted look in the bedroom ceiling, by running collar ties above the wall plates,and then build the rear ceiling to the front hip section.More of a coffered look.
Or you could build a shallower pitched gable on the addition and then run an overhang across the front, at the same level as the new roof ,to break to the height and have a hip like appearance.
If possible,step the second floor out from the first floor on the side , like the original house to break up the height.This would possibly take away from your garage size,but could improve the looks.
I wish I had a way to draw it up,but I don't have the software.
oldfrt is offline
Old 02-28-2009, 09:27 AM   #14
Dufus Extrodinaire
BHR's Avatar
How about this. I went back to a hip against what the wifey wanted. I'm sure she would understand the drama involved with gableing the front. Thing is there would be no vault ceiling in the bedroom since the roofline is so shallow.
Does it look right?
BHR is offline
Old 02-28-2009, 10:57 AM   #15
Joe Carola's Avatar
Does it look right?
That looks alot better. You would have to keep the main addition pitch the same as the existing pitch to flush the roof. Also, you have to put a cricket at the top of the entrance roof to shed the water.
Joe Carola
Old 02-28-2009, 11:47 AM   #16
Trailer park boy
shanekw1's Avatar
Does it look right?
If you use the lower pitch roof line in your second pic, why can't you gable the front?
shanekw1 is online now
Old 02-28-2009, 12:41 PM   #17
General Contractor
greg24k's Avatar
Does it look right?
What software did you use to make that drawing?
Old 02-28-2009, 12:43 PM   #18
Dufus Extrodinaire
BHR's Avatar
We had looked at that and felt that because the exsisting roof is shallow (6/12 - I think) it would look very odd with such a tall front wall.
Thanks Joe! I would assume the person drawing the plans would show the cricket and the framer would know it's required - but it is good for me to know before hand - so thank you.
I'll have to see about trying to do something in terms of vaulting the ceiling when I sit down with the planner. I'm sure there would be something that could be done that would be pleasing.
You guys are the best!
BHR is offline
Old 02-28-2009, 12:46 PM   #19
Dufus Extrodinaire
BHR's Avatar
I just used an imaging software - took a picture then copied it out in a line drawing with the software then adding colour/features
Program was PhotoImpact10 - real easy to use, great tools in it
BHR is offline
Old 03-01-2009, 03:46 PM   #20
General Contractor
greg24k's Avatar
Thanks BHR!
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 07:52 PM
Animal House Electric Bubbles Electrical 15 01-22-2009 01:37 AM
Company Growing! In house accountant resources? Help! ds6154 Business 1 01-11-2009 10:32 AM
Can a house be built for under 50K? healthyhomes General Discussion 35 12-10-2008 09:24 AM
House moving Toolwh@#e Excavation & Site Work 10 10-21-2007 11:23 PM
