Minor Framing Estimating Help
Old 04-12-2004, 05:04 PM   #1
Bah Humbug!
Grumpy's Avatar
I am bidding on a mold remediation project right now. The mold was caused due to ZERO intake ventilation on the English Tudor style home.
As part of my remediation, I am giving an option to build out the overhangs and create some soffit ventilation. We've done this once in the past by ripping off the fascia sistering the rafters and installing a new fascia on our new rafters.
This is my plan again, but I can't find any record of how I can up with my pricing structure. Woops!
The rafters are 2x4 24" OC and I have a total footage of 200 linear to be built out.
Here is a step by step of what is going to be done:
1) Tear off existing fascia board.
2) Sister some rafters to hang out at least 10", probably with 2" attached to the exiting so total length 3'.
3) Mark and cut rafters so they are all of equal length.
4) Install a frieze board against the brick.
5) Install a fascia board on the new rafter butts.
6) cap fascia and freize board with aluminum, and install vented soffit panels.
7) Install new gutter.
Any advice? 1 story easy access. If I add everything up I come up with $31 per linear ft.
Grumpy is offline
Old 04-12-2004, 05:34 PM   #2
General Contractor
hatchet's Avatar
Re: Minor Framing Estimating Help
That seems a little cheap for the demo, replacement framing, and touch-up of the roofing that's sure to be damaged, and the replacement roofing of your additional overhang. Although I haven't taken off any materials or anything best guess per linear foot of soffit you have around 10 linear feet of 2x4 for framing, plus sheathing (cost is ever rising). With waste you're looking at over 2000' of 2x4's. That's just off the cuff mind you.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 04-12-2004, 06:29 PM   #3
Custom Builder
Glasshousebltr's Avatar
How old is the structure?
Can you look in to see the top plate?
Some of the older homes have the birds mouth cut so deep you can't sister anything. I'd check this out, or you might get stuck installing soffit sub framing to hold up the overhang.
most framers get at least 3 bucks a square foot on install alone. But take into account they also set doors/windows in exterior openings.
Material? I'd just do a take off and add it on plus 15%.
Then I'd add your roofing and soffit/facia rates. POW....you should be there.
Bob
Glasshousebltr is offline
Old 04-13-2004, 07:12 AM   #4
Bah Humbug!
Grumpy's Avatar
Were doing the roof anyways. Total resheat of the decking due to mold so that isn't a problem. Nowhere near that many feet of 2x4. Were only going to be sistering the bottom ends. We have a total of 200' of fascia to build out. Rafters are 24" OC. If I take a 3' board, sister two of those feet and leave one foot hang this will give me a total of 450' linear of 2x4. Again sheating wasn't figured into the price because the job is already a total resheat... but good catch!
No way to see the top plate without doing some demo. The building is about 80years old if I have to guess. I don't see many English Tudor new construction
Grumpy is offline
Old 04-13-2004, 03:22 PM   #5
General Contractor
hatchet's Avatar
IC.. I was figuring that you would need another 2x against the existing wall to frame in the bottom of the box soffit and another out at the face as a sub-fascia. Maybe I'm used to doing commercial too much - where I put in factor of safety of 8 like all the engineers.. haha.
Rich
hatchet is offline
Old 04-13-2004, 07:01 PM   #6
Bah Humbug!
Grumpy's Avatar
Well I made my presentation and I think I really impressed the guy. I approached him with some CAD drawings of my two proposed overhang build outs as well as my other detailed literature. He was very impressed with the fact that I bid to clean his rafters instead of replacing them. That's going to save him about $15,000, probably more.
I should know if I won the sale no later than Thursday. Thanks guys for your help!
Grumpy is offline
Old 07-07-2004, 09:45 PM   #7
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
What would the price per foot be to install aluminum soffit and facia? Its on a new home the overhang lengths vary but probably average 14 inches. One sectioin of the house is 2 story. Thank You.
Old 07-08-2004, 11:56 AM   #8
Bah Humbug!
Grumpy's Avatar
About $8 a linear foot but that's just guessing without knowing all the details.
Grumpy is offline
Old 07-11-2004, 07:25 PM   #9
Unregistered
Guest
Posts: n/a
I'm looking for a price for exterior stucco.I believe its called drvit.Can anyone steer my in the right direction. Thank You.
Estimating help Sparky General Discussion 16 04-10-2011 08:12 PM
Anyone Make Their Own Excell Spreadsheets for Estimating? TurnkeyConst Technology 1 03-17-2007 11:49 PM
Estimating programs Alkyd Painting & Finish Work 9 02-19-2006 07:01 PM
What is your way of estimating? saucedo80 Painting & Finish Work 7 11-05-2005 11:08 PM
Estimating Article Series hatchet Business 15 07-15-2004 12:47 PM
