Trade: GC/Developer
Marking Layout Lines So They Stay Longer Then Chaulk
I have a house that i rebuilding but the foundation is out of square(cant be fixed as it is a row house up against another house)
We have replaced the joists and have put down the first floor plywood. Because the house is out of square so bad the guys can't work off the plans only as compromises need to be made. I am looking to lay out the whole floor the night before framing and have them work off the lines i laid. If i use chaulk lines the rub out really fast. i could use carpenters pencil but i find that even rubs out sometime with people walking over it. is there something else i could do that would last longer? |
It is what it is
Trade: Roofing, Remodeling, Concrete
Re: Marking Layout Lines So They Stay Longer Then Chaulk
What color chaulk are you using?
unlicensed hack
Trade: wood butcher
Red is permanent.
I usually don't have this problem with blue though. If it is getting light, I'll just resnap before setting walls.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
It is what it is
That's what i was thinking. Sometimes blue will get wiped or swept off. In dusty or high traffic areas i use red and never had a problem.
Ruane Woodworks,LLC
Trade: Finish and Custom Trim
Buy some hairspray and spray it over the chalk lines.
Trade: GC/Developer
i had no idea red was more perminant. i will have to try the hairspray trick too..
Clear laquer in a spray can works well too.
#8 | |
Trade: Framing Contractor
Re: Marking Layout Lines So They Stay Longer Then ChaulkQuote:
I know you said the house is up against another house, but is it between two houses? If not, how bad is it out of square where you can't cheat the three walls in and out if the one wall is up against one house?
Joe Carola |
Remodeling Contractor
They make a clear coat to go over marking paint and chalk lines, I use it all the time and works great.
http://www.aervoe.com/aervoe/shoppin...etail.asp?ID=9
"Man is a tool-using animal. Without tools he is nothing, with tools he is all." Thomas Carlyle (1795-1881) |
Trade: GC/Developer
Thanks for all the great ideas.. i will have to look for that clear marking paint, that way i can also write notes in pencil and seal them up.
the issue with the house is that it is a row house that has a party wall on each side. Those party walls are 3 inchs out of square in 60 feet. i am framing a new wall inside of this and can square that wall but then i lose 3" across the buildings 20 foot width. the architect plans show a full 20' of width which i really dont have once i square things off so i need to figure out where i can steal those 3" from and either notate the plans or work with my super to mark it out. i would rather just mark it out that way even the dumbest guy can figure it out. |
#11 | |
When he drew the plands, he didn't know the house was 3" out of square so you can always make field adjustments. It happens every day.
Joe Carola |
Trade: GC/Developer
that is exactly what i was planning. i need to make the stairs/halls/kitchens and baths really square and will cheat elsewhere.
most of my projects are rehab of 100 year old row houses so the cheating isnt new. the guys can follow the plans but i need to tell them where i want to cheat. i just had no idea the red chaulk was rated to last longer. but it says right on it the bottle that it is more water resistant. my issue is i will not be there on framing day so i need to lay everything out for them. i bought the red chaulk and some spray laquer to preserve any notes i am sure it will work fine |
#13 | |
Used hairspray once, didn't like the end result. |
Bah Humbug!
Take a strong, lay it out. Then take a spray paint and spray the string. Then remove the string. You will have a "Reverse" chalk line.
jack of all, master of 1
Trade: carpenter/roofer
[QUOTE=Grumpy]Take a strong, lay it out. Then take a spray paint and spray the string. Then remove the string. You will have a "Reverse" chalk line.[/QUOTE
had to do that before. Just make sure it's disposable line. |
Trade: General Contracting
We frame apartment buildings and run into that kinda stuff all the time. One foreman goes through and lays all the walls out with black chalk. I know a lot of people don't like black for various reasons, but that is about as permanent as you can get. If there happens to be inclement weather in the forecast, he will spray everything with clear spraypaint.
-John We'll have to grab a longer board. I forgot to put the wood stretcher in the truck today. |
miterclamp.com
Trade: interior trim/cabinets
I used to use masonry tint when I was laying out, then spray it with water from an indian pump.
Comes in all kinds of colors and sold by the pound. Pretty cheap too. |
#18 | |
FRAME ON!
Trade: Decks,All phases of remodeling,
#19 |
Dream Maker
Trade: residential construction
i use an ink line. i have red ink and black ink. tajiba is the brand name. INK YO!
#20 |
Trade: GC/Developer
I used the red chaulk and spray laquer..
I am the contractor, I wanted to be able to lay the whole for floor out in advance so the workers could just knock out the walls. Also I was hopping to be able to take a day off and leave the second in command there. I wanted to make things as easy as possible on him when it comes to figuring out where to cheat. |
| People who work at desks should stay there! | theworx | General Discussion | 33 | 10-12-2009 01:07 PM |
| Bonding Plastic Water/Gas Lines? | jevorik | Electrical | 3 | 12-29-2006 12:24 AM |
