Making A Shed Door From Hardi Board - Page 2 - Carpentry - Contractor Talk
Old 08-03-2017, 07:25 AM   #21
P.R.O. Fessional
Chipfo's Avatar
Rewards Points: 200
Re: Making A Shed Door From Hardi Board
Originally Posted by woodyacd View Post
I`ve got 2 of those on my shed. almost the same design.
and I`m embarrassed to say I should have known better ,
it was a lousy choice of materials .
on a windy day one of the doors slammed open hard .
the hardy-backer broke off. its kind of brittle . its water proof , but doesn`t really take a beating well.
I`d go with a good pine or cypress "t&g" , and then put your cross members to keep it straight , and racked.
glued and screwed with deck-screws .
if your worried about rot, paint it with " wood-life" preservative before you paint it.
just make sure you PAINT THE BOTTOM !!
I used LP Smart side and same with trim, used liquid nails and screws and let the door lay flat overnight to let the adhesive dry. I also put pieces of scrap 1 x 4's on the backside where each hinge is to receive longer hinge screws for added strength
Making a shed door from hardi board-doorliqnails.jpg   Making a shed door from hardi board-sheddoor3.jpg
I've cut this board three times and it's still too short!
Chipfo is offline
Old 08-03-2017, 10:48 AM   #22
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
Originally Posted by rayh78 View Post
You can even goggle Hardi siding Delamination
So that's where all those counter samples went......
"Nobody is more inferior than those who insist on being equal" -Friedrich Nietzsche
Krok is offline
Estimating with Excel for the Small Contractor YouTube cargin2 Business 123 01-13-2018 03:45 PM
Shed roof Tylerwalker32 Decks & Fencing 12 06-05-2013 09:06 PM
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 03:30 PM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
determining skirt board height romoranger Finish Carpentry 2 07-07-2009 01:46 PM
