Log Vs Traditional
Old 09-14-2006, 06:46 AM   #1
ContractorTalk Flunkie
dayspring's Avatar
Log Vs Traditional
I have a log home I'm working on. We already built one addition to it and the client wants another. As H/O's do, they want to save money. We used log siding for the previous addition, and it looks very good ( has the log ends and such to match the rest of the house made by the same manufacuer as the original logs. The H/O believes that it will be cheaper to build the new addition with logs rather than stick build with log siding.
I have never used logs before, I can do it, but never have. My question is to those that have done it. Is it cheaper, bottom line (material and labor) to use logs? From ever angle I have looked at it, logs seem to be about 30% to 50% MORE (material and labor), plus these new logs will have to be cut to fit into the existing structure, which don't appear to be a real simple task in itself due to the thickness of the logs, siding would be much easier.
Any input or advise?
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 09-14-2006, 06:55 AM   #2
Dream Maker
Mr. D's Avatar
Trade: residential construction
Re: Log Vs Traditional
the material should be cheaper, but the labor will be more to go with full logs. mistakes are cheaper w/ stick framing.
Mr. D is offline
ridge vent versus traditional vents signal15 Roofing 16 02-11-2011 05:16 PM
Traditional or non-conventional...? joasis General Discussion 39 12-28-2007 01:02 PM
installing ceder shake(vinyl) versus traditional lap siding 72chevy4x4 Windows, Siding and Doors 1 05-08-2007 08:18 PM
Traditional Cut Roofs tarty Roofing 14 06-19-2006 08:35 PM
Metal versus Traditional Shingle Roof 4powells Roofing 14 02-21-2005 07:25 PM
