Level Decks On The Top Floors
Old 11-11-2006, 09:57 AM   #1
adman1900's Avatar
When building a multi story residential stick frame building what method do others use to ensure a level deck surface once your off the poured concrete foundation. The way i was shown was to us a laser level in the basement. Find a level baseline all the way around the basement walls. measure up the wall then shim or plane the next floor (ex +1/8, +1/4, -3/16. Is this a common practice to have two more stories essentially resting on shims. Of course point loads are put in at all bearing points. What methods do you guys use to ensure level decks on the upper stories when building out of a concrete hole
adman1900 is offline
Old 11-11-2006, 11:20 AM   #2
reveivl's Avatar
Trade: Renovations
Re: Level Decks On The Top Floors
Why isn't the concrete level?
reveivl is offline
elevation tool??? ck 4 level floors samiam Tools & Equipment 7 09-29-2007 02:10 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
Pool Decks Patton Painting & Finish Work 1 05-14-2007 09:52 PM
Help with refinishing floors!!!! KellyPainting Painting & Finish Work 12 01-20-2007 11:26 PM
Multi-level decks specwood Carpentry 3 03-14-2006 04:33 PM
