Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry
Old 10-25-2009, 02:56 PM   #1
Trade: General contractor
Laminating Ipe
OK, after a few tries at steaming Ipe I realize it will not bend as much as I need it to. Next I will try to laminate the shapes I need.
I have read many negative things when it comes to gluing Ipe. I just can't see blocking these treads. The curves above are made with Azek and they are long clean curves with very little joints. If nothing else I may learn a few things while trying.
The finish treads will be about 12.75" made up of three 4.125" strips formed to about a forteen foot radius. (laminated from 1/2" strips) To help compensate for the poor gluing characteristics of Ipe I plan to install ss threaded rods and nuts about every foot. I will then bung the ends to hide the mechanical fastening. At leas this way, if a glue joint fails the treads will still hold thier shape.
So my two qestions are:
1) what type of glue/ epoxy would you try?
2) does this have any chance of success?
I did make a sample piece in my shop using a urithane adhesive and I did like the way it looked but several of the joints did not take that well.
crovello is offline   Reply With Quote
Laminating drywall over plaster Frankawitz Drywall 13 10-13-2009 06:09 AM
Laminating concrete steps JK Floors Flooring 7 07-28-2009 08:57 PM
New board or laminate over existing d's Drywall 16 03-06-2009 09:59 AM
