Knotty Pine Ceiling
Old 07-03-2006, 10:23 AM   #1
skidmark845's Avatar
Trade: carpenter
Knotty Pine Ceiling
I will be having a knotty pine ceiling installed in a floriday room ceiling.
when the panels get installed, do you stagged the legnths?
skidmark845 is offline
Old 07-03-2006, 10:29 AM   #2
Teetorbilt's Avatar
Re: Knotty Pine Ceiling
I always stagger the planks. IMHO a seam would need to be covered by a false beam or some other trim.
Make sure that the moisture content of the wood is low before installing, ceilings shrink worse than flooring and large gaps are not attractive.
Albert Einstein
Teetorbilt is offline
Old 07-03-2006, 11:57 AM   #3
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Here are some pictures of one that I just finished. I too would stagger the joints. I like to stagger each row by at least two joist or more.
Dave.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 07-03-2006, 01:41 PM   #4
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
Stagger works good. IMHO
A+Carpenter is offline
Old 07-03-2006, 02:57 PM   #5
Trade: carpenter
WOW, those were pics were great, thanks alot...!!!!!!
Old 07-05-2006, 02:05 PM   #6
Trade: carpenter
Guys another question, I think I should have gone to the DIY site but anyway, how and where do you nail the boards to the ceiling?
Thanks again
Old 07-05-2006, 02:18 PM   #7
Master Craftsman
Big Dave's Avatar
In the pictures that I posted I only nailed the tongue like you would nail hardwood flooring. I did face nail the butt joints though.
Dave.
Big Dave is offline
Old 07-05-2006, 04:44 PM   #8
DGFVT
CE1's Avatar
Trade: Electrical
Try this one it is a Vermont room and was done a few years ago. It's 12' x 20'.
Attachment 2432
CE1 is offline
Old 07-05-2006, 06:02 PM   #9
Teetorbilt's Avatar
To do away with having to hit the joists, get a more random pattern and save material, you can go 2 ways.
On high-end work, I go to 2 routers with T&G bits. When price is an issue, I go to a couple of quickie jigs for the biscuit cutter. Both take ending on the joists out of the picture and eliminate face nailing.
Albert Einstein
Old 07-05-2006, 06:03 PM   #10
Custom Builder
Glasshousebltr's Avatar
I bevel and glue the joints.
Bob
Bob
Glasshousebltr is offline
Old 07-05-2006, 06:19 PM   #11
Teetorbilt's Avatar
I don't glue. The humidity here fluctuates too much.
Albert Einstein
Old 07-13-2006, 11:53 PM   #12
kodiak_island's Avatar
Trade: remodel retrofit
Send a message via MSN to kodiak_island
Hey Dave nice work
kodiak_island is offline
Old 07-14-2006, 05:31 PM   #13
Finally went Pro
ruger9's Avatar
Trade: General Contracting/Remodeling
Big Dave- that's beautiful, man. How did you get that color? What stain/finish did you use?
Where do you guys get your T&G from? A local lumber yard wouldn't sell me the quantity I needed for a whole room (76), because it would "wipe out their inventory"... I ended up getting them from big-box, but had to hand-weed-out all the "bananas" (twisted and/or warped planks)...what a P.I.T.A!
ruger9 is offline
Old 07-14-2006, 08:20 PM   #14
remodeling contractor
P construction's Avatar
Thats some nice work
I just finished to additions with all western red ceder
the smallest was 2600 LF
P construction is offline
Old 07-14-2006, 09:25 PM   #15
Master Craftsman
Big Dave's Avatar
It was a little bit of work. First of all we decided to install the car siding on upside down so that the center grove would not be seen. It made it look too busy.
Second we went through all of the car siding and cut out all of the bad spots and cut the peices to a 16" interval.
Then we fired up the router with a chamfer bit and routed all the ends.
After that we sanded all of it to even out the color and get rid of any defects like crayon marks and foot prints and so on.
Then we stained all of it. We used a minwax stain but I can't remember the color.
EDIT: After looking back through the minwax stain colors I think it was Puritan Pine.
After it was installed, the painter sprayed on the sealer and laquer.
I get my wood from a lumber yard that specializes in log home stuff and they keep several hundred if not thousands of feet on hand at all times.
Dave.
Big Dave is offline
Vertically installed suspended ceiling Maplehead Remodeling 13 03-29-2007 10:06 PM
Help!!! T&g Knotty Pine Removing Black Streaks arnldmtman Construction 5 04-02-2006 10:43 AM
Raising ceiling height in the LR and D- room. marcotte64 Construction 2 04-02-2006 10:33 AM
Drop ceiling question Eric K Remodeling 5 12-16-2005 07:47 AM
