Joist Hanger Question - Carpentry - Contractor Talk
Old 11-20-2017, 03:59 AM   #1
bmbcontracting's Avatar
Trade: Interior remodeling
Rewards Points: 88
I know Simpson Strong tie has their book of approved nails for their engineered connectors.
Here is my question. When fastening the hanger to the header/beam, you have to use 6-10d nails, commonly known has joist hanger nails because the have great shear strength since those few nails are essentially bearing all the weight sitting on the joist.
However, the holes on the joist hanger which nails are toe nailed through the joist and into the header/beam see little to no shear tension. This is the area I want max pull out resistance.
Is it wrong to to use hex head construction screws?
bmbcontracting is offline
Old 11-20-2017, 04:38 AM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Re: Joist Hanger Question
Yes. Unless specified as acceptable by the Manufacturer.
Check the product listing on their website.
jlhaslip is offline
Old 11-20-2017, 05:16 AM   #3
Rewards Points: 88
Well I know that, but I was looking for some actual data or anything because i can not find a single resource .
On paper, those toe nail holes in hangers don?t even have to be filled for the hanger to do it?s job.
Key word on paper.....see someone blowing that out of proportion real quick.
Old 11-20-2017, 06:30 AM   #4
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,634
Simpson does make an approved screw.
https://www.strongtie.com/strongdriv...onnector-screw
Home Designer Series Software
B.Johnson is offline
The Following 3 Users Say Thank You to B.Johnson For This Useful Post:
greg24k (11-21-2017), Rio (11-20-2017), ScipioAfricanus (11-20-2017)
Old 11-20-2017, 08:09 AM   #5
tjbnwi's Avatar
Rewards Points: 4,960
The toe nail holes are for pull out not shear.
I use a longer nail in the angled holes.
tjbnwi is online now
hdavis (11-20-2017)
Old 11-20-2017, 10:14 AM   #6
hdavis's Avatar
Rewards Points: 3,149
I don't see why the adequacy of nails would be a concern. These connections used to be made with only toe nails.
If you want the greatest withdrawal, you use clinchers, not screws.
hdavis is offline
Old 11-20-2017, 10:22 AM   #7
VinylHanger's Avatar
Rewards Points: 8,204
Yep. I am always seeing 2x4 porch structures attached with two nails toenails into the fascia. Been there for 40 years or more.
VinylHanger is offline
Old 11-20-2017, 10:26 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 2,646
Yes to all of the above, also if you follow the Simpson guidelines when using their connectors everything will be fine as long as your construction practices are up to snuff, they're not going to be selling a product that is going to fail under normal conditions.
Rio is online now
Old 11-20-2017, 07:21 PM   #9
cvtsf's Avatar
Rewards Points: 228
In fact most of the Simpson Hangers will work under extreme conditions, like hurricanes and earthquakes.
cvtsf is offline
Old 11-20-2017, 07:37 PM   #10
Tom M's Avatar
Rewards Points: 7,750
Which sku/model hanger are you talking about? The book is very thorough in providing info and options for Max strength.
Tom M is online now
Old 11-21-2017, 08:56 AM   #11
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
if you're that concerned about pull out... (insert joke) then use a cs strap over the top
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 11-22-2017, 07:24 AM   #12
Tom M's Avatar
If you had access to the other side you could throw a deck tension tie in there at a couple of spot.
Tom M is online now
Deck Screws vs Joist Nails subybohn Decks & Fencing 105 06-25-2018 06:54 AM
Joist question out of curiosity pibe Framing 13 11-30-2014 07:32 PM
Question for those of you who have been injured on the job tyb525 General Discussion 15 08-07-2013 12:54 PM
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
