#21 |
Project Manager/Carpenter
Trade: Carpentry/Reno
Re: Which Joint For Column Wrap
If it is PVC it should be "straight".
#22 |
KemoSabe
The biggest complaint I have toward PVC trimboards is slight variations in thickness, even within the same board. I've seen them vary as much as 1/8" in thickness in an 18' length.
It's uncommon, but always seems to bite you when you least expect it.
#23 | |
Re: Which Joint For Column WrapQuote:
Lone-did you dado it? if so, and it's 3/4", did you glue a piece on the back for reinforcement (imagining a 1/2" cut would leave little material). |
#24 | |
Maker of fine kindling
I figured even the mosquito races went big time sense then too. All my victories were small time local stuff at Echo Farm Campground. Still have the ribbons though. Not to worry, I know NJ is a beautiful state.
Every parent who has walked barefoot into their child's room late at night hates Legos |
#25 | |
With the 5/4 material, I have seen and 1/8th from end to end as well. That was certainteed brand, I have been using Kleer and it seems to be a bit better, but I have run PVC through a thickness planer to resolve this issue, not that its something I want to actually do. |
#26 |
Trade: siding
how does the planer leave the surface of pvc?
Tom |
#27 |
Re: Which Joint For Column WrapI have planed the certainteed and it leaves a nice finish
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan |
| The Following User Says Thank You to PA woodbutcher For This Useful Post: | Tom Struble (09-10-2009) |
#28 |
It leaves the surface like a saw cut, porus, but still smooth. The time I needed to do it , I only needed 1 good face, so I only planed 1 side and left the factory face exposed. If your planer is variable feed speed, run at high speed as this will keep the chips from gumming up. The shavings are funny, sort of like that fake snow they use on movie sets.
Speaking of factory edges, has anyone tried the Azek with the Edge feature??? I used to use Azek years ago, but my supplier switched to CT, then to Kleer as CT's prices got out of hand. |
#29 |
......I am not sure. I noticed the Azek Edge samples in my lumberyard and I bought 7 lengths of 1x12 a few weeks later....I think my lumber yard still has the old stuff b/c the sample was MUCH less porus then the 1x12 I had....
#30 |
topsail's trimcat
when i clad posts, mosts times be it azek or wood ill butt joint them but on the wider piece ill make it 1/4" more than the standard flush width and give a 1/8' reveal to the joining piece.
this allows for movement and creates shadow line
putting down subfloor with glue and screws, well i saw dr. smith and the robot too , i had a martian burger and a sonic shake |
| The Following User Says Thank You to woodworkbykirk For This Useful Post: | Tom Struble (09-10-2009) |
#31 |
Trade: siding
i like the reveal to Kirk
Tom |
#32 | |
KemoSabe
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | Tom Struble (09-10-2009) |
#33 | |
Trade: Architectural/Historic Restoration and Preservatio
Generally speaking, Cellular PVC only expands and contracts in one dimension, lengthwise (or parallel to the direction that it was extruded in).
Spires & Co. Architectural and Historic Restoration, Preservation, Design, and Consulting http://www.spiresco.com/ |
#34 | |
Who's PVC are you using? I do not have this problem with Kleer.
#35 |
KemoSabe
Found this on several occasions with Azek, usually only minimal variations, but on a beveled joint it can be a PITA.
#36 |
Trade: General contractor
Re: Which Joint For Column Wrap |
#37 |
Uber-Member
Trade: Carpenter...Deck Guy
In PVC post wraps......Butt joint, Bond & fill structural adhesive and SS nails or trim screws. I've never had an issue using Azek, Kleer, CT or that other brand I can't think of right now that starts with a P I think
#38 |
Trade: siding
his on Jeff?
http://www.plasticlad.com/
Tom |
| Tub-Tile joint, grout or caulk?? | Aframe | Ceramic & Stone Tile | 11 | 06-27-2011 02:55 PM |
| Biscuits or a routed glue joint? | OW! My thumb | Finish Carpentry | 27 | 03-25-2009 09:36 AM |
| joint compound under carpet for gaps. | mechanix | General Discussion | 3 | 12-10-2008 03:49 PM |
| Rubber expansion joint? | wellbuilthome | Masonry | 4 | 10-25-2008 09:38 PM |
| Butt Joint problems | AARC Drywall | Drywall | 10 | 09-14-2008 03:40 PM |
