Which Joint For Column Wrap
Old 09-07-2009, 01:18 AM   #1
Anderson's Avatar
Trade: Home improvement contractor
Question
I am replacing 3 columns on a porch with 6x4 PT lumbar. I will be facing it with PVC. SHould they be jointed with a 45 miter ?
Anderson is offline
Old 09-07-2009, 01:42 AM   #2
Re: Which Joint For Column Wrap
Hello.
Please read this....
http://www.contractortalk.com/f11/ju...portant-60787/
neolitic is offline
Old 09-07-2009, 10:24 AM   #3
PA woodbutcher's Avatar
Real subtle Neo
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 09-07-2009, 10:50 PM   #4
Anderson's Avatar
I didn't realise that the guys on here where so paranoid. I am a home owner that is true, but I am also a business owner, licensed and insured with about 3 years of property management under my belt. I am sure not alot compared to most on here.
I am sick of getting back advise from people I know in the trades who seem to send me in the wrong direction so I did a little searching and tried here.
I guess I will not ask any more questions until I have 9000 posts in then I will be a real contractor.
Anderson is offline
Old 09-07-2009, 11:55 PM   #5
Tom Struble's Avatar
Trade: siding
miters are not traditionally used on wood trim outside generally,moisture and movement tend to open the joint up over time
with the pvc the joints can be ''solvent welded'' and they will probably stay tight
just its not the traditional look that you may be trying to achieve
Tom Struble is online now
Old 09-08-2009, 12:04 AM   #6
solar guy
naptown CR's Avatar
Trade: solar contracting
The coefficient of expansion on PVC mateial could be problematic. either use a corner lock glued well with sufficient room for ecpansion and contraction or use a butt joint
naptown CR is offline
Old 09-08-2009, 01:47 AM   #7
lavrans's Avatar
Trade: General Contractor, Woodworker
PVC? But joint. glued & nailed.
lavrans is offline
Old 09-08-2009, 07:08 AM   #8
KemoSabe
loneframer's Avatar
I mitered all of these.
Which joint for column wrap-020-2-copy.jpg   Which joint for column wrap-025-2.jpg   Which joint for column wrap-038-copy.jpg
loneframer is online now
Old 09-08-2009, 08:24 PM   #9
Anderson's Avatar
Thanks guys for all the advise, I think I am going to butt glue and nail. Although the Loneframers miters are very nice.
Anderson is offline
Old 09-08-2009, 08:29 PM   #10
Grand Rapids Remodeling
Paulie's Avatar
Hey lone, whats the extra large cupola room going to be used for? The work looks great by the way.
www.phbconstruction.com
Paulie is offline
Old 09-08-2009, 08:34 PM   #11
Trade: siding
they always are
i like the subtle shallow dado detail very nice
loneframer (09-08-2009)
Old 09-08-2009, 08:37 PM   #12
I like Green things
WarnerConstInc.'s Avatar
Plastic domino's!!
Plastic biscuts.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 09-08-2009, 09:34 PM   #13
KemoSabe
loneframer's Avatar
That is an observation tower overlooking the river and wetlands. There are a bunch of neat critters around, including Bald Eagles, Red Tailed Hawks and Osprey, as well as deer and turkey on a regular basis.
Which joint for column wrap-044-copy.jpg   Which joint for column wrap-045-copy.jpg
The Following User Says Thank You to loneframer For This Useful Post:
Paulie (09-08-2009)
Old 09-08-2009, 09:44 PM   #14
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Is that where the announcer for the mosquito races sit come sun down?
I hear they actually have saddles and jockeys too. Any truth to that?
Gus Dering is offline
Old 09-08-2009, 10:36 PM   #15
Trade: siding
Gus you gotta come to N.J. sometime
i talk with people for other places and they have this preconceived notion of what NJ is
this state is screwed up like every other state
but there is beauty here to,just gotta know where to find it
and yes you can saddle the big ones
Old 09-08-2009, 10:48 PM   #16
Don't know about that.
I do remember going to watch
the submarine races.
There weren't any announcers though.
neolitic is offline
Old 09-09-2009, 01:30 AM   #17
KemoSabe
loneframer's Avatar
Who you trying to kid? I heard you logged the most wins as a jockey at your campground outside of Sea Isle City back in the day.
Old 09-09-2009, 05:17 AM   #18
KentWhitten's Avatar
You want to experience death by mosquitos? June in deep woods Maine.....sunset. THEY will saddle YOU, bitch slap you around some, use you, then suck you dry leaving a decrepit corpse.
I send visiting New Yorkers there. Massachusetts (Massholes?)have caught on, they're no fun anymore.
BTW, mitre. Butt joints while easier are perfectly described....butt....
Salmon Falls Cabinetry
KentWhitten is online now
Old 09-09-2009, 09:35 AM   #19
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
If you are going to miter, you might as well lock miter....
http://grizzly.com/products/C1711
TBFGhost is offline
Old 09-09-2009, 10:55 AM   #20
tccoggs's Avatar
Certainteed uses lock miters on their pre-made PVC corner boards and they are very strong. I droped a 2FT peice from a scaffold, and it hit the driveway and while the end was mangled, the joint was fine. I noticed that other manufactures are using miter fold technology which assuming your stock is straight, is and excellent method that you can do without alot of clamps.
tccoggs is offline
Tub-Tile joint, grout or caulk?? Aframe Ceramic & Stone Tile 11 06-27-2011 02:55 PM
Biscuits or a routed glue joint? OW! My thumb Finish Carpentry 27 03-25-2009 09:36 AM
joint compound under carpet for gaps. mechanix General Discussion 3 12-10-2008 03:49 PM
Rubber expansion joint? wellbuilthome Masonry 4 10-25-2008 09:38 PM
Butt Joint problems AARC Drywall Drywall 10 09-14-2008 03:40 PM
