Installing Interior Doors
Old 03-14-2006, 09:36 PM   #1
Richie-C's Avatar
I'm installing some new pre-hung interior doors in my home. Here is the scenario--I tried installing one today. My rough opening is 33" wide and the Masonite door I am installing is a 32 x 80. It fits into the rough with some tapping persuasion and a 1x up top for fill. Ar first I was worried that it was too tight, but the doors opens and closes nicely and is perfectly plumb and level. Is this snug fit going to cause problems down the road? Or is it ok as long as it opens and closes nicely??
Thanks,
Richie
Richie-C
Richie-C is offline
Old 03-15-2006, 07:16 AM   #2
ContractorTalk Flunkie
dayspring's Avatar
Re: Installing Interior Doors
If everything is plumb and square, door margin (gap between door and jamb) is proper (1/8") and consistant, I don't see any problem. A properly installed door unit would be shimmed so it would stay in place anyway. For future reference, a door opening should be framed 2" over the door size, 32" should be 34", etc. This allows for shimming to plumb and square door unit in a out of wack opening.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 03-15-2006, 09:31 AM   #3
RowdyRed94's Avatar
Trade: Residential custom home builder
+1. Your only real concern is the header. You don't want that tight to allow for settling. I don't even shim single door headers - just let the casing carry the head jamb so if the wall does settle it's an easy adjustment.
We frame 2-1/4 over for single doors and 2-1/2 over for double. If the jamb is 3/4 on each leg, that leaves you with 3/4 inch to split on either side for shimming.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 03-15-2006, 05:48 PM   #4
Richie-C's Avatar
Thanks for the reply--the header has plenty of room--the sides are tight, but the door opens and closes just right. I have four more to do, so I was nervous to keep going with that method. I could just get narrower doors and shim the heck out of em.
Thanks!
Richie-C
Richie-C is offline
Old 03-15-2006, 05:48 PM   #5
dayspring's Avatar
True if you leave that much room, it may not sag, however if you are using a 2 x 10 or 12 header, as you should, you'll never have a sag in a 3 ft opening. I never, ever frame with less than a 2 x 10 header. You may want to take precautions installing double doors but again, a 2 x 12 header, crowned when built and installed, is not likely to sag, Never seen one do it yet. Not in a 6 ft opening. Anyway, we've all got our ways and ideas. That is what mekes carpentry interesting for me.
T.C.
installing new thru-wall flashing @ existing wall. TAO Masonry 5 08-08-2007 05:26 PM
Looking for tips on installing interior doors mtheisen0814 Carpentry 12 07-23-2007 11:09 PM
best method of installing ceiling in garage 72chevy4x4 Construction 11 01-26-2007 08:02 AM
Installing exterior door jdmtrim Finish Carpentry 5 12-31-2005 08:20 PM
Installing wood in a guest house Bob H Flooring 12 12-05-2005 11:33 AM
