I Joist Bridging
Old 07-13-2011, 08:24 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Question
I Joist Bridging
Well I am wondering of you guys use the metal bridging when installing tji joists. I worked for a contractor where we did not, but i am not sure if he was trying to save money by not putting them in or if they were not necessary.
bluebird5 is offline
Old 07-13-2011, 08:39 PM   #2
Dirtywhiteboy's Avatar
Rewards Points: 8,048
Re: I Joist Bridging
I've used them some times and sometimes not
Dirtywhiteboy is online now
Old 07-13-2011, 08:47 PM   #3
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 900
The I joist installation guides don't require it if the bottom of the I joist has drywall installed. We will put furring strips 4' oc in our crawl spaces to act as lateral bracing. I suspect bridging would also be fine.
overanalyze is offline
Old 07-13-2011, 09:05 PM   #4
bluebird5's Avatar
Rewards Points: 694
so of it is on a floor on the first story where there is no drywall below, they are recommended?
Old 07-13-2011, 09:07 PM   #5
Always Learning
Rewards Points: 900
It is how I read the guides. The I joist need something to keep them vertical..they don't sag as much as they flex side ways...
Old 07-13-2011, 09:15 PM   #6
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
No... but we always strap the ceilings anyway.
Brutus is offline
Old 07-13-2011, 10:43 PM   #7
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Never
Would like to see instructions for I joists that require.
Framer53 is offline
Old 07-13-2011, 11:18 PM   #8
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
we don't really either.
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 07-14-2011, 07:45 AM   #9
richardframing's Avatar
Trade: wood framing
Rewards Points: 75
Hughjazz, In alberta at least here around the calgary area when you look at most floor system designs they take all the information into account. The floor system will be designed for a certain live/dead load. It will take into account wheather there is gypsum applied to the underside of the joists. Some joist designs even take into consideration large islands with granite on them or other such loads like offset bearing walls. In alberta either they dont or certain codes do not exist that force framers to put strapping or bridging underneath the floor system where as other juristictions require it possibly due to siesmic factors. The best example i've seen is two floors with exactly the same span and having different joist ratings. The reason the basement had a heavier joist was to accomodate the fact that there wasn't a drywalled ceiling to stiffen it up. Either way blocking or bridging = squeaks.
richardframing is offline
Old 07-14-2011, 05:47 PM   #10
bluebird5's Avatar
Rewards Points: 694
Originally Posted by Framer53 View Post
Never
Even though it is not a requirement, will it benefit the floor by putting it in? I guess i am just wondering why people put bridging in dimentional lumber but not I joists.
Old 07-14-2011, 05:49 PM   #11
Always Learning
Rewards Points: 900
The guides I have read have not required it..but they do recommend it. I will look it up at the office and try to post a link later.
bluebird5 (07-14-2011)
Old 07-14-2011, 05:53 PM   #12
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
The last I knew there was discussion about whether bridging actually works, so I guess most likely there is no need for it.
I am not an engineer and would like to hear one's thoughts on this...
Framer53 is offline
Old 07-14-2011, 06:51 PM   #13
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Metal strap bridging is a joke. On conventional lumber, you can make it tight enough to play a tune and within a month or two, there is so much play in it, it's virtually useless for its intended purpose, which is to distribute load to adjacent joists, or "load sharing". Lumber shrinkage is the culprit. The drive in type is much better, as it gets tighter as the joists shrink.
I personally prefer 1x3 or 1x4 pine for X-bridging. I staple it in with 3-4 medium crown staples on each end, to prevent splitting.
Here's a little thing I did awhile back using X-bridging. Check it out. I know it's not real world conditions, but it shows the theory behind distributing a concentrated load to the entire joist system.
http://www.contractortalk.com/f14/fu...ridging-68111/
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
Old 07-14-2011, 06:53 PM   #14
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,483
I only put the bridging under the parallel non load bearing walls!
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Framer53 (07-20-2011)
Old 07-14-2011, 07:12 PM   #15
KemoSabe
loneframer's Avatar
Here's a link I grabbed from the other thread.
+ YouTube Video
Old 07-14-2011, 07:20 PM   #16
bluebird5's Avatar
Rewards Points: 694
haha... are you a git er done framer?
Old 07-14-2011, 08:39 PM   #17
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
Don't know how you get so many replies when you post a negative comment for your second post in the last couple threads you started...
But, it's an interesting topic.
Metal bridging? Last time I saw that was in condos built in 1980. Do lay-out to archies specs (I don't, not just a framer). No puns, don't get architectural drawings. If they're laid out to specs, adding blocking at key-load points ( then I don't believe it matters). Strapping the bottom with 1x's would help more.
Guilford, CT Remodeler and Carpenter Web-site Twitter@CraftsmanJay
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 07-20-2011, 02:32 PM   #18
Robert carozza's Avatar
Trade: Master carpenter
Rewards Points: 75
Bridging is not required for "I" joists unless the underside is left exposed in which case a 2by4 is fastened midspan and perpendicular to the underside of the joist.
Robert carozza is offline
Old 07-20-2011, 02:42 PM   #19
Rewards Points: 75
<a href="http://www.youtube.com/watch?v=R_OF9KgWhzI">YouTube Link</a>
The 3rd example is pretty cool but that would add some $$$ to the cost of the job
Old 07-20-2011, 04:26 PM   #20
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Want to give me a link to the specs that say that please?
Framer53 is offline
Deck Screws vs Joist Nails subybohn Decks & Fencing 101 05-26-2018 05:54 PM
Replacing rotted rim joist entry door...first timer! r1dannyzx Carpentry 22 04-20-2011 04:06 PM
Joist hanger for dropping down a joist to beam connection Btrbimmer Decks & Fencing 4 10-05-2009 11:07 PM
just to say hi and ask a question - floor joist spacing Old Sawdust New Member Introductions 13 11-19-2008 09:53 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
