How To Tile A Shower Floor???
Old 02-12-2007, 04:14 AM   #1
CALKAM's Avatar
Trade: Carpenter/ Remodeller
Lightbulb
Hello All,
Just got this shower room job and dont know much about how to do the floor. I installed dozens of shower trays till now but this time the customer wants tile floor. I am a carpenter with good tiling experience. I would be very happy if anyone explains just how to do the floor in a shower room step by step.
Thanks
CALKAM is offline
Old 02-12-2007, 04:16 PM   #2
Professional Remodeler
firemike's Avatar
Re: How To Tile A Shower Floor???
Go to http://johnbridge.com/vbulletin/index.php and a little searching should give you all the info you will need.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 02-16-2007, 07:41 PM   #3
hanover's Avatar
Trade: Home Improvement Contractor
another good one is http://www.floorstransformed.com
hanover is offline
Old 03-03-2007, 03:49 PM   #4
Handyman's Avatar
Originally Posted by CALKAM View Post
Hello All,
Thanks
I don't know if it's a little late. But, you can do it a couple of ways. I've done it with a rubber lining and in fiberglass. I liked the fiberglass way better. If you still need help with it, I would be more then willing to answer any questions you may have.
Handyman is offline
Old 03-15-2007, 11:12 PM   #5
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
oh oh pick me pick me OK go to home depot and get a book on tile sounds kinda dumb yea I know what you tile pros are thinking but at least it will have some photos for him you have to build your pan first then put down your linner then float your mortar so it will slope to your drain 1/4 per ft should do it adjust your drain up for the tile it is not a easy job for a first timer mix your mortar kinda dry then put down your thin set and lay your tile out side working in towards the drain good luck with it the first one is the hardest be sure and charge a lot it is a lot of work not like doing floors a 3x3 ft pan is about 600 what was your bid on this ?
hrscammisa is offline
Old 03-15-2007, 11:18 PM   #6
hrscammisa's Avatar
Trade: carpentry
I read your post agian How big is the floor ? and what size is the tile and where are you located
Old 03-19-2007, 08:23 PM   #7
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
This was over a month ago. Maybe he's already tiled the floor by now?
In_Mexifornia is offline
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Porcelain Floor Tile - fixing sanded grout cracks ETHICS05 Flooring 11 07-18-2007 07:43 AM
Ceramic tile over concrete floor Handyman62010 Flooring 14 03-15-2007 09:40 PM
curb in tile shower floor. fastg60 Ceramic & Stone Tile 48 03-13-2007 12:46 PM
Floor dilemma (tile failure) Knyte260 Flooring 4 03-16-2006 07:35 PM
