How To Scribe A Segmental Arch.
Old 11-04-2007, 08:39 PM   #1
zccarpenter's Avatar
Trade: Frame and finish carpentry
I'm framing a segmental arch across a 16' garage opening. I know how to scribe/calculate normal arches by finding the radius but the radius to this arch will be over 15 to 20' (i.e. take up too much room to layout). The opening is 16', the sides come down 8" on each side to 0" in the middle. What's the best way to scribe this without snapping a bunch of lines and rotating on a string?
zccarpenter is offline
Old 11-04-2007, 09:07 PM   #2
Al Smith
A W Smith's Avatar
Re: How To Scribe A Segmental Arch.
why cant you lay it out on the driveway, ground or deck with a steel tape and onto a 2x12? I did this for a 20 foot arched garden bridge over a creek last year.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 11-04-2007, 10:20 PM   #3
curapa's Avatar
Trade: Carpentry / Fencing / Decks
Find the center of your opening, measure up to your desired height, take a piece of flexible trim ( 1/4" round or similar) while holding the two lower ends at the desired locations bent the trim up to the center mark. Have someone scribe the trim.
Get a firm but bendable piece of trim to avoid a wavy scribe mark.
curapa is offline
Old 11-04-2007, 10:50 PM   #4
Trimwerx's Avatar
^it can take a little experimenting to come up with a piece that'll bend just right for that procedure, but it is a really easy way to do it.
Trimwerx is offline
Old 11-04-2007, 11:04 PM   #5
If you're using azek on the job, it has the perfect properties for that trick--including the 18' length.
neolitic is offline
Old 11-05-2007, 04:02 AM   #6
I used to think so.......
wallmaxx's Avatar
I like to calculate everything I can. In your case draw out a grid reference on plywood and play connect the dots. Sorry for the W I D E image. I needed the size to scale the dimensions to keep them readable.
Best of luck to you.
v/r
Mike
wallmaxx is offline
Old 11-05-2007, 06:22 AM   #7
karma_carpentry's Avatar
Trade: carpenter
That is great, WallMaxx. What kind of calculations did you use? Did it involve Sines or Cosines?
Build on a good foundation.
karma_carpentry is offline
Old 11-05-2007, 09:42 AM   #8
Charitable animal
Bone Saw's Avatar
Trade: decks
auto cad, I was about to post the identicle dwg last night, but the post count of op made me think twice
Bone Saw is offline
Old 11-05-2007, 10:13 AM   #9
wallmaxx's Avatar
Bone Saw ACad.
I use a scientific calc in RPN. The eqn is :
S SQ R SQ 4 * + 8 R * /
then convert to feet and draw it.
wallmaxx is offline
Old 11-05-2007, 06:24 PM   #10
Thanks for all the useful tips. My size ended up changing to 12" down on either side to 1.5" in the center. I found an equation (Rise Squared + Span/2 Squared)/2xRise. My Radius ended up being 37'. Also, I found a nifty little way in my Layout book. However, there is stuff all in the way in the garage, the driveway is dirt and has a dumpster in the middle, so there is no real room to make a pivot point and scribe (except maybe on the golf course outside). So, tommorrow I think I will try Wallmaxx's method (thanks, by the way). And as for using flex trim and scribing, I may be trying that also.
frame and sheetrock an arch ch0mpie Carpentry 30 12-08-2010 12:00 PM
i need a perfect arch and i dont have the room newnoise Introductions 8 03-27-2007 08:56 PM
Question about a arch building? wraiths Electrical 2 10-24-2006 09:00 PM
Arch fault breakers edirector Electrical 17 08-25-2006 03:27 PM
Arch prices 6stringmason Masonry 4 02-28-2006 07:41 AM
