How To Replace Rotten Pole Barn Poles In Ground
Old 07-02-2009, 11:04 PM   #1
smeagol's Avatar
Trade: new construction and remodeling
It is a 20 year old shed. the post are rotted and are just sitting on the ground(above ground good yet). Should i put the new post next to the the old and notch together or put new one underneath with 2x6s on sides? Anyone any prior experience? Thanks ahead
smeagol is offline
Old 07-02-2009, 11:46 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Re: How To Replace Rotten Pole Barn Poles In Ground
Smeagol,
I have seen it done several ways. A lot of farmers will dig down beside the old post and put in an new 8' post about 3.5' in ground and 4.5 out. then bolt through old and new post with about three 3/4" threaded rod.
One of the local businesses in Indiana started manufacturing an cement base with a metal spade that can be inserted into the good portion of the old post. Some guys are using this for new construction as the cement base is rated for 50 years I think.
I have personally sandwiched old posts and boxed them in also. Usually overlap at least 3 feet.
More than one way to skin this cat.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
The Following User Says Thank You to dakzaag For This Useful Post:
fez-head (07-03-2009)
Old 07-03-2009, 06:08 AM   #3
Farmer Boy's Avatar
Trade: Custom Horse Barns
Check out this web site permacolumn.com I have never replaced a post with a perma column but it seems like a good option.
Farmer Boy is offline
Old 07-03-2009, 08:00 AM   #4
genecarp's Avatar
genecarp is offline
Old 07-03-2009, 08:56 AM   #5
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Build temporary braces to support the shed walls. Then just cut/pull/dig the old one's out. Then re-plan the entire layout--digging your new post holes.
Darwin is offline
Old 07-03-2009, 09:36 AM   #6
stp57's Avatar
Trade: carpenter/ handyman
Originally Posted by dakzaag View Post
Smeagol,
I don't know what kind of post hole digger you have, but I can't go further than 2 1/2 feet with mine. The handles get boxed into the hole (unless you widen the hole big enough to bury your neighbor's Rottweiler?)
Steve
stp57 is offline
Old 07-03-2009, 09:50 AM   #7
Lack Of All Trades
Darwin's Avatar
Steve
Maybe he used an auger? Hmmmmm
Darwin is offline
Old 07-03-2009, 07:52 PM   #8
katoman's Avatar
Trade: carpenter
We did a complete professional riding arena. Here is how we did it -
1- House moving company supported structure with cribbing.
2- Cut off rotten posts about 4' off ground
3- Had backhoe excavate for new sono tubes, and poured new 18" tubes, four feet deep. With anchors.
4- Installed new posts in anchors up to the cut off posts, then installed new 2x lumber both sides of posts.
5- Remove cribbing and you're done.
katoman is offline
Old 07-03-2009, 10:32 PM   #9
dakzaag's Avatar
Trade: mason
Steve
Helps to be smarter than the tool your using.
If you fill the digger with dirt, you don't need a big hole to pull it up. I used to set 10' posts in the ground 5' like that. (I was a lot tougher and more desperate back then.)
If your digging in bedrock or something like that, get a mounted auger.
D K & Sons
dakzaag is offline
Old 07-06-2009, 11:14 PM   #10
smeagol's Avatar
thanks for the input. I am going to auger down 4 1/2 feet, throw a cement cookie in there, pound it down with the new 8' post and notch out 2 " of the existing post for some bearing then use 3/4" threaded rod and some torx screws
smeagol is offline
Old 07-19-2009, 09:48 PM   #11
72chevy4x4's Avatar
I would suggest bury 3' and leave 5' up-use four 1/2" carriage bolts to hold the two posts together. No need for the notching out of the old post-if anything, if you're intent on doing so, use a 4x6 to sister and slip the full original 4x4 onto the 2" notched out new 4x6...but for a regular shed that would be a bit overkill.
72chevy4x4 is offline
Pole Barn Garage mrmike Carpentry 26 10-28-2009 08:29 PM
Pole Barn Framed Garage? J-Peffer Construction 12 05-25-2009 08:49 AM
large slab in pole barn tomscarpt Masonry 17 04-04-2009 04:41 PM
Pole Barn Feeder sparkysteve Electrical 4 10-21-2006 08:57 PM
Concrete floor in a pole barn thinkncabin Masonry 3 03-31-2006 06:45 PM
