How To Replace A 60-80's Window?
Old 09-24-2009, 02:47 PM   #1
abacab's Avatar
The old ones are easy, just pop out the stop. In the past I've always replaced the entire window, party because of homeowner request, and because I prefer it. However, how would I use these replacement units when the trim appears to be nailed to this stop? I'm sure there's got a be a way to do it, with all the window replacement guys I see running around. do they take off the trim?
abacab is offline
Old 09-24-2009, 03:01 PM   #2
JonM's Avatar
Re: How To Replace A 60-80's Window?
In this day in age where 75 percent of phones have a camera...pics sure would assist your explanation...
JonM is offline
Old 09-24-2009, 03:10 PM   #3
W-Tinc's Avatar
Trade: Student
I used to see alot of wood dh's in Mich where the stop is actually about 1.5" wide and half of it is under the casing, nailed to the jamb. if thats what you mean then yup, take casing off or install from outside.
W-Tinc is offline
Old 09-24-2009, 03:18 PM   #4
Framer53's Avatar
Trade: Framing
Or get your chisel or MM out and remove it!
Framer53 is offline
Old 09-24-2009, 05:59 PM   #5
abacab's Avatar
I hadn't thought about doing it from the outside, I'll have to look into that one. Yes, I see a lot of 1 1/2" flat stock with the trim nailed over half of it. You'd think they would have made those windows so they could easily install replacement vinyl windows, like they did for us at the turn of the century.
I never find any directions on how to install these windows in that type of window, everything is geared toward the older windows with stops.
I also never see much on just replaceing the side jambs, don't know if they are any good.
I'd take pictures but I'm not currently privy to these types of windows. My house has the old beveled leaded glass with stops, and so I put storm windows on.
abacab is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Replace Basement Window w/ Glass Block firemike General Discussion 7 08-19-2009 09:18 AM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Best method to replace a window with vinyl siding importer Carpentry 3 04-11-2008 09:10 PM
