Help With French Door Install!
Old 12-23-2017, 07:09 PM   #21
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,265
Re: Help With French Door Install!
That guy have problem. I guess he is in northern mn and there will be cold next week. Mn cold not Ca cold.
tipitop is offline
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task!
Old 01-01-2018, 12:01 PM   #22
MknAsDad's Avatar
Rewards Points: 24
after looking at Marvins installation instructions, theres 2 things that can be a problem. Both are related. They recommend using a construction adhesive under the sill and they showed the adhesive put on in a swiggle formation.
Both of those are a bad idea. What should be used is a sealant under it instead of adhesive because the sealant will flex.
The problem with swiggle lines with the sealant is that you very well can have pockets that the sealant isnt making contact with the bottom of the threshold, thus areas that the water/air can infiltrate.
MknAsDad is online now
French Drain into Solid Drain catahoula Excavation & Site Work 4 07-22-2013 08:02 PM
Wet basement french drain vs. footer drain moorewarner Excavation & Site Work 20 03-21-2010 07:30 PM
At we cater exlusivly to professional contractors who make their living as a contractor. Knowing that many homeowners and DIYers are looking for a community to call home, we've created DIY Chatroom is full of helpful advices and perfect for DIY homeowners.
