topsail's trimcat
Hand Nails Or 18 Gauge Staples, In Cedar Shingles
im currently working on a quote for a shed to be built, they want cedar shingles on it and im wondering if using a stapler does a decent job of fastening them, ive hand nailed nailed, and gun ring nailed them never stapled..
the job is out of the way for me and im willing to buy a stapler but not a ring nailer. feedback would be greatly appreciated
putting down subfloor with glue and screws, well i saw dr. smith and the robot too , i had a martian burger and a sonic shake |
Trade: Deck Builder
Re: Hand Nails Or 18 Gauge Staples, In Cedar Shingles
The way the grain is most shingles I think nails would make them prone to split. On all the cedar shake gazebo roofs that I do they are stapled. Use a narrow crown stapler not a wide crown stapler & turn the pressure down some.
KemoSabe
Ridgid has an 18 ga. stapler thats not bad, shoots up to 1 1/2" staples. I always use stainless steel. The staples hold very well, I use 2 per shake, regardless of width.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
topsail's trimcat
cool thanks guys, working on a more detailed drawing from the clients original sketch... funny thing is they want shingles, board and batten and clapboards all in one. no problem hand nailing the clap boards, and gun nailing the b&b i have the guns for that,
anyhow. just a matter of doing the take off and the project being a go ahead
Project Manager/Carpenter
Trade: Carpentry/Reno
Re: Hand Nails Or 18 Gauge Staples, In Cedar Shingles |
Trade: Framing
i've used both ring shank siding nails and crown staples. both do a fine job.
Trade: siding
18 ga. no good 16 ga.7/16 crown only as far as staple go
http://www.cedarbureau.org/installat...ual/page05.htm
Tom |
Trade: Renovations
I've been stapling them for years never had a problem.
#9 | |
Trade: Construction Assistant Superintendant/Remodeler
Re: Hand Nails Or 18 Gauge Staples, In Cedar ShinglesQuote:
Do you find it gives more of a solid hold? Only delt with 1 or 2 cedar shake siding jobs and used hand bangs (spiral shanks). (worked for a GC and that's what they used) Never heard of using staples. I'm NOT debating the use of just stating my lack of experience with. |
Was wondering about that myself. I'd guess that the wider the crown, the more likely the shake would be to split but thats just my guess.
#11 | |
Trade: Deck Builder
#12 | |
I was/am only familar with 1/2"or less so I was thinking you ment like a 1/4" as being the "small". ( like in underlayment) AGAIN I was sleeping in class the day the discussed diff. crown staplers!
Trade: general contractor
The wider crown limits where you can lay the shingles without exposing a staple in the expansion crack.
#14 | |
KemoSabe
topsail's trimcat
hmmm interesting, i had been hearing they curl and pull away, so if i get this project ill drop the coin and get a stapler.
ive used staplers for building my window jamb extension boxes with a stapler before, i found they are stronger than a pinner, screws work as well but slower and cost more. just a matter of seeing whats in my budget for how good a gun i get
Trade: General construction
Anyone know the best jig to use when placing shakes up the wall?
I think I remember one guy using a simple board with maybe a piece of step flashing fastened on the ends. It had another piece of strapping as a simple dam to insert a row of shingles before just using the staple gun to staple off that entire row. He pushed the step flashing under the bottom of the last course. If I am thinking correctly, it is a way to keep each row locked in the next position 5,6,or so inches above the last. And what about using a laser? I want to be able to place a whole row of shakes in a trough or hold down strap and then staple that row, move up and keep them straight, and do it with some speed. I know that's asking for a lot. |
Trade: siding
i usually just snap a line,then place the shingle to just cover it
i used an 18 ga stapler on cedar shingles once i use 16 ga or stainless siding nails now i just don't have the confidence that some do in them too light gauge for exterior work IMO cedar shingle bureau has the recommended fasteners listed 18 ga not listed as an acceptable fastener
Tom |
#18 |
wannabe
Trade: carpentry
I've never used a stapler...not to say I wouldn't. We've always handnailed.
The only advice I can offer is to make sure the shingles are squared and jointed to move along at a good pace. Even then, there's a lot of block plane work to keep your gaps even. My method to stay straight is to snap a line, then nail a 1x ledger through the gaps with a 6 finish hand nail.
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
#19 |
Trade: Exteriors
I also snap a line with runner then run a string line at 1 inch above reveal mark which holds the course in and then nail the course off all at once. I have always used nails myself.
I would actually like to know how many guys do thier field work first and then do thier pitch work at the end on thier gables I have always done my pitch work first then fill my field but I see alot of guys going the field first |
#20 |
Good advice guys
I just had a thought! (unusual yes) Use a piece of J channel on top of a length of strapping. Think it would help? |
| Stripping shingles off of ice guard | manland2319 | Roofing | 15 | 09-09-2009 12:19 PM |
| Cedar shingles, advice please | swanee | Windows, Siding and Doors | 17 | 06-15-2009 09:33 PM |
| cedar shingles walls | Silvernails | Windows, Siding and Doors | 3 | 03-08-2009 01:56 PM |
| cedar shingles | wink | Roofing | 22 | 10-08-2008 07:36 AM |
| Cedar shingles | Nail banger | Windows, Siding and Doors | 6 | 07-09-2008 09:42 PM |
