#21 |
Trade: builder/renovator,Squam Lake NH
Re: Garage Service Door Ideas
You should be able to get a steel door in any size, I have order them as small as 3'-0 x 3'-0 for a crawl space.
One of the first jobs I worked on we were building a barn for a HO that owned a small factory and he would differentiate between doors as overhead doors or personal doors (walk through) We have been calling them personal doors ever since. |
#22 |
Trade: Garage doors, openers and garage door repair
I have also custom made a few doors that size, any size is possible.
Garage Door Repair Pros - Garage doors, openers and garage spring repair at 2105 15th Ave Sacramento, CA 95822 916-282-4720 Garage Door Repair |
#23 |
Trade: Electrical & Carpentry
You can definately order the steel door cut down to that size opening. I have just ordered one from the local lumber yard. You can have it cut evenly top and bottom which will be more money or just off the bottom which is cheaper. Even Home depot & Blowes can order them like this.
I have also cut them off at the bottom & re-inserted the "wood bottom" that I cut off- back in between the steel panels with a good glue..... hope this helps........ |
#24 |
what type of glue do you use mrmike?
#25 |
I have used PL Premium contruction adheasive. Just make sure it can bond to metal & wood & be for interior/exterior. There are other brands also.
By the way when you cut the piece off, you will have to seperate the metal off of the wood on that piece, which is pretty easy. install glue liberally to both sides & smoothing it on the wood so it is adhered & then inserted into the door bottom & clamping it for a bit. |
#26 |
The simplest, fastest, and least expensive
option remains, order an outswing and slide it into the existing opening...
#27 | |
Re: Garage Service Door IdeasQuote:
. It is usually about $100 more to have them special ordered to shorter heights so it would make sense to order the outswing for that opening. Again it is up to him if he wants to spend the money or try to retrofit that existing door |
#28 | |
![]() It's like you said, extra bucks for special order door, or labor to cut down the door and jambs, then labor and materials to fill in the opening inside and out, and you still have an oddball looking door .... I think the last Therma-Tru out-swing unit I ordered was only about $30-$40 more than the standard unit. That mostly pays for the threshold and tamper resistant hinges.
| The Following User Says Thank You to neolitic For This Useful Post: | mrmike (03-23-2010) |
#29 |
Thom
OK, this has to be one of the worst threads on CT.
The OP calls himself a carpenter/contractor with $10G worth of tools he's storing in the garage yet he doesn't know: 1. there are security hinges for outswing doors 2. door suppliers will cut doors to any size 3. he can cut a door and jamb himself Last edited by thom; 03-22-2010 at 02:06 PM. |
#30 |
wannabe
Trade: carpentry
This isn't the cheapest route, but my folks had the exact same problem...it may be helpful for folks with the opportunity to look ahead.
We used a wall mounted overhead door opener. This allowed an almost zero ceiling clearance for the tracks. http://www.gate-opener.com/liftmaster_3800.html
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
#31 | |
![]() ![]() ....and yet some really good ideas can pop up in some of the threads that start with the dumbest premises.
#32 | |
Trade: Carpenter/Contractor
Thanks to everyone else for the help. As for you thom, worst thread? You sound like a bitter old man. Go yourself.
#33 |
#34 |
What's funny is there are a few other threads asking the same question. Guess I should have looked around before asking a dumb question.
#35 |
It isn't your question,
it's your response to thom.
#36 |
My response to thom was in line with his response to the thread. It was disrespectful. If someone disrespects me they get the same in return.
I AM a carpenter/ contractor and a damn good one! |
#37 |
garage door guy
Trade: Garage doors
That's a great idea wnycarpenter. I always come up with a better idea after i do the job. Now i have a place to get some idea's.
Garage Doors - Openers & Spring Repair is located at 2610 Union St Oakland, CA 94607 510-214-8901 Garage Door Repair |
| How to Pay Piece Meal and Sleep at Night | dirt diggler | Business | 34 | 03-13-2011 10:54 AM |
| Service Magic's new service | Grumpy | Marketing & Sales | 12 | 08-02-2008 04:31 PM |
| Garage service question | Edsollen | Electrical | 15 | 12-14-2006 07:21 PM |
| May offer a New Service ?? | tzzzz216 | General Discussion | 15 | 07-16-2006 12:00 PM |
| Aluminum 200 amp service | banctecbobn | Electrical | 7 | 06-07-2006 01:57 PM |
