Garage Floor Decking
Old 11-10-2008, 06:26 PM   #1
ALL VINYL
all vinyl's Avatar
Trade: VINYL SIDING CARPENTRY
hi
I'm getting ready to frame in my garage floor . THE question is after I put down vis queen is it OK to put Doug fur floor joist on top of or does it have to be pt . I know my plate has to be but I was just told from a builder that you can not use pt inside a house because of fire and gases emitted.
all vinyl is offline
Old 11-10-2008, 06:42 PM   #2
genecarp's Avatar
Re: Garage Floor Decking
What do you mean frame your garage floor, why isnt it concrete? do you have a crawl space under it? you are going to drive on a wood garage floor?
genecarp is offline
Old 11-10-2008, 06:50 PM   #3
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Originally Posted by all vinyl View Post
hi
and then you said......
WTF? Is it a Garage floor or is it in your house?!
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 11-10-2008, 06:53 PM   #4
ALL VINYL
all vinyl's Avatar
i was waiting for it. the garage is an atatched garage and i'm going over the concret floor with floor joist now should they be fur or pt ??? what you think
Old 11-10-2008, 06:55 PM   #5
Restoration Crazy
So you're converting it to a room?
Facebook | Twitter
Old 11-10-2008, 07:00 PM   #6
ALL VINYL
all vinyl's Avatar
sorry about that I'm converting it into a third bedroom master sweet with bath and hook up for washer and dryer . I'M going over the floor with X to give me enough room for pipes and insulation.
Old 11-10-2008, 07:02 PM   #7
genecarp's Avatar
If you are on plastic, Doug fir is fine for the joists. do not use acq for the joists.
ps, dont rip every floor joist to conform to the old garage floor, hang the system a little high, and shim to the concrete floor as required, there will be no direct contact to the garage floor with the fir. you can rip shims out of acq if you wish..
genecarp is offline
Old 11-10-2008, 07:03 PM   #8
dkillianjr's Avatar
I would go with PT joists. I have never really heard anything about the gases or anything like that nor have I ever had any problems with the PT. Just make sure when you nail your plywood down or wall plates, ect., you use gavinized nails aproved for treated wood, especially if its ACQ. I'm still gettin some of that down here.
dkillianjr is offline
Old 11-10-2008, 07:06 PM   #9
Restoration Crazy
I might even suggest you bring the plastic up the walls, about an inch above the sub floor to be sure no moisture gets in there. (assuming theirs no ventilation underneath)
Facebook | Twitter
Old 11-10-2008, 07:06 PM   #10
ALL VINYL
all vinyl's Avatar
thanks
I no wew did some decks this year with the acq I no its difrent but the splinters still smart a lot more then df. I appreciate the help good luck out thier .
Old 11-10-2008, 07:24 PM   #11
ALL VINYL
all vinyl's Avatar
thanks the garage is all cinder block so visqueen floor and walls like a basemeant . thier will be ventalation from the crawl space on the house and out the side . :
Old 11-10-2008, 08:30 PM   #12
Pressure treated joist is just
asking for trouble.
You don't need PT,
you don't want PT!
It's interior, we don't do interior
framing with PT, especially YP.
It will have shrinkage issues.
It will warp while it dries.
It will leave excess unnecessary
moisture in your under floor.
No PT joist.
If you need extra grief in your life,
just tell your wife that the jeans
do make her ass look fat.
neolitic is offline
Old 11-10-2008, 11:40 PM   #13
orange Garrison's Avatar
Trade: general contracting/carpentry
use super 6 poly and red tape it!cover the floor and leave some (about 3 inches )up the wall.You should get yourself some acoustic seal and run a bead about 2 inches up the wall then push the poly tight to it. build your subfloor and enjoy. lasts 20 years on average.
orange Garrison is offline
Old 11-11-2008, 06:30 AM   #14
ALL VINYL
all vinyl's Avatar
Question
asking for trouble.
You don't need PT,
you don't want PT!
No PT joist.
ok now i'm confused fur should not touch concret ot it will rot ,pt will shrink and warp
Old 11-11-2008, 07:02 AM   #15
genecarp's Avatar
your floor joists should not be touching concrete, see my previous post #7.
genecarp is offline
Old 11-11-2008, 07:18 AM   #16
ALL VINYL
all vinyl's Avatar
thank you i must have missed the post or just brain dead that is wha=t I was going to do make a box out of Doug fur and bolted into block wall and sleepers out of ccq were needed tanks alot
Old 11-11-2008, 07:27 AM   #17
genecarp's Avatar
You got it, only your box and plates need to be acq, joists to be df.
genecarp is offline
Old 11-11-2008, 07:28 AM   #18
ALL VINYL
all vinyl's Avatar
time to frame
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
...continued...garage floor drain progress carlspackler Plumbing 0 05-27-2006 02:54 PM
