Free Wood Spiral Staircase Plans?
Old 11-13-2006, 05:17 PM   #1
Flooring? What's that?
J DoubleD FLoor's Avatar
Trade: Flooring
I just purchased a home and am planning on putting in a spiral staircase and was wondering if anyone had plans or a link for some free plans.
Quality is not expensive ... It's PRICELESS !!!
www.neoflooringco.com
J DoubleD FLoor is offline
Old 11-18-2006, 06:26 PM   #2
my own boss
supercrew's Avatar
Trade: carpenter
Send a message via Yahoo to supercrew
Re: Free Wood Spiral Staircase Plans?
if your asking about free standing wooden spiral staircases i think you might be out of luck with the free plans. as far as a wall holding up both outter stringers, i seen this on a "home improvement" show days before a HO decided thats what they wanted. i got promoted from laborer to framer instantly.
i only built one so i might miss a point.
1. find your arc. we plumbed down from the start and set our end point. cut plates out of 3/4 plywood, 3 1/2" strip cut to the radius
. we got both inner and outter plate from 1 4x8 sheet. then using a formula that escapes me, we framed the "spiral" walls so the step was like 7" on the inside and 11" on the out. we made a story board for the rise and ran a 2x from wall to wall and down to floor, creating each rise. sorta like having a header at the back of each step which supports the front of the nex step. the most solid staicase ive ever built.
i only work off drawings
supercrew is offline
Old 12-16-2006, 03:45 PM   #3
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
there is alot of factors to figure in that just some free plans. What kind of dimension in your space do you have for spiral stairway. They are not complicated to build by any means however they is alot more lumber involved than a straight run.
JustaFramer is offline
min. clearance for spiral staircase? born2drv General Discussion 0 08-15-2007 10:56 AM
Free Wood Spiral Staircase plans? J DoubleD FLoor Flooring 4 11-14-2006 04:18 PM
Spiral staircase for Trex deck Woodcrafter74 Landscaping 2 11-21-2005 11:21 AM
