Framing Walls On A Sloped Slab
Old 08-10-2017, 03:27 PM   #21
GC/carpenter
Californiadecks's Avatar
Rewards Points: 2,750
Re: Framing Walls On A Sloped Slab
You can just chalk it on the ground if you can't use the CM. CM is the best most efficient way.
_________________
Californiadecks is online now
Old 08-10-2017, 09:56 PM   #22
hdavis's Avatar
Rewards Points: 3,625
If you're just cutting to get an even slope, measure your slab drop, and "square up" one end of the studs to match the drop, then gang cut the other ends. Same approach as
No marking, and no individual cutting. It's my go-to method. Basically, Larry Haun's technique for cutting a bunch of studs to the same length, but the un-cut ends are lined up out of square to get the right drop, and the other ends cut square as usual.
I don't know how you'd get more efficient than that.
hdavis is offline
Old 08-10-2017, 10:29 PM   #23
Irishslave's Avatar
Rewards Points: 1,528
If the drop is a even 4" (straight line no undulation) on a 30' run each stud is gonna be about 1/8 longer (4.00/30 = 0.133) 3/16" at the most
This crap wouldn't even pass around here...if slab is grade foundation must be min 8" above grade and if a conc man can't pour a level foundation stuff him in the redi-mix truck
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is online now
The Following 2 Users Say Thank You to Irishslave For This Useful Post:
Californiadecks (08-10-2017), SmallTownGuy (08-11-2017)
Old 08-11-2017, 06:42 PM   #24
Rewards Points: 746
The fastest way is to use the method I described. It has the least measure and calculating. This is an old method that was taught to me and lots of guys back in the day here and JLC forums used this.
It was/is a standard way of framing on slabs that are all over the map.
My experience is that nothing fits perfect in the field that is drawn on a computer, especially framing on concrete. Once you've got a good flat surface you can draw and make a cut list, eg for rakewalls.
As a production framer, learn to love your laser and chalk line
Timuhler is offline
The Following User Says Thank You to Timuhler For This Useful Post:
Californiadecks (08-11-2017)
Old 08-11-2017, 07:16 PM   #25
hdavis's Avatar
Agreed.
hdavis is offline
Old 08-14-2017, 01:03 AM   #26
51carpenter's Avatar
Trade: Carpenter Contractor
Rewards Points: 200
Construction master here, just did this a week ago on a garage. It was a shed roof so I used the calculator to figure the rake walls which were level, then I used it to figure the side walls which were on the slope of the slab.
Took a little playing to get the calculator figured out, usually I just use it for stairs and finding diagonal lengths when checking square.
How many use the calculator for rake walls?
Professional wood welder
51carpenter is offline
The Following User Says Thank You to 51carpenter For This Useful Post:
Stilla (11-11-2017)
Old 11-10-2017, 09:46 PM   #27
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Good day,
I have been lurking around these forums for a bit and decided to make a account. I was just reading this thread and I can’t for the life of me figure out why you guys would pour a slab 4” out of lvl for a garage? I’m I missing something.
MeanWeen is offline
Old 11-10-2017, 11:14 PM   #28
hdavis's Avatar
So water drains out, otherwise could get water pooling in the garage.
hdavis is offline
Old 11-11-2017, 12:08 AM   #29
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Are we not talking about a garage here? Water from what? Your car?. Seems crazy, if I showed up to one of my sites and somebody sloped the entire slab 4” to drain the water out the front door I think I would laugh, then cry, then skid everyone.
MeanWeen is offline
Old 11-11-2017, 01:06 PM   #30
Stilla's Avatar
Trade: Finish carpentry
Rewards Points: 592
Originally Posted by J.C. View Post
I've never had to do it but, I think I'd probably use a laser level to calculate the slope and construction master to tell me the stud lengths.
Easy to do with the balusters function with the construction calculator buildcal.
Stilla is offline
Old 11-11-2017, 01:13 PM   #31
402joel's Avatar
Trade: carpenter
Rewards Points: 281
Sloping a garage floor here in snow country is mandatory
NRA Life Patron
SAF Life
402joel is offline
Old 11-11-2017, 01:16 PM   #32
hdavis's Avatar
Drive around in snow, then park your truck in the garage. You'll wish that slab was sloped.
hdavis is offline
Old 11-11-2017, 01:28 PM   #33
Stilla's Avatar
Rewards Points: 592
I don't use a calculator for framing, but use a calculator for finish work, which is the same. I use buildcal. It's an app for the phone.
Stilla is offline
Old 11-11-2017, 01:36 PM   #34
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
I’m sorry guys, I live in northern Canada. You can put a small sump in middle of floor, even dig in a 4” pvc pipe and get finisher to put a small slope to that. The whole “live in snow country I seem what happens” thing doesn’t make sense. So what happens when you drive in the snow melts and rushes out towards the garage door and freezes the thing to the ground? There is so many things wrong with this method I still don’t understand why anyone would do it. Not trying to be a dick. Do you guys supply shims for the customer when they want to put some free standing shelves in, or some wheel chocks for the dude when he is sitting in his chair having a beer
MeanWeen is offline
The Following 2 Users Say Thank You to MeanWeen For This Useful Post:
shanewreckd (11-16-2017), Stilla (11-11-2017)
Old 11-11-2017, 02:03 PM   #35
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Ok, one more quick question then I am moving on, if the customer wants a man door in the “rake wall”, do you hang it plumb, install out of plumb but good with slab or try to convince won’t meet code.
MeanWeen is offline
Old 11-11-2017, 03:22 PM   #36
hdavis's Avatar
You can insall these plumb and square and meet code pretty easily. It isn't a side hill, it's maybe 1" in 5' or less slope.
hdavis is offline
402joel (11-11-2017)
Old 11-11-2017, 04:22 PM   #37
slowsol's Avatar
Rewards Points: 2,194
Do you also install the code mandated oil/water separated for that drain?
Garages are sloped here. But typically their is a stemwall that is level installed around it first. Slab gets back poured. Garage walls don’t need to be angled then.
-John
slowsol is offline
The Following 2 Users Say Thank You to slowsol For This Useful Post:
402joel (11-11-2017), overanalyze (11-11-2017)
Old 11-11-2017, 04:30 PM   #38
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 342
This is how all ours are done.
overanalyze is offline
Old 11-12-2017, 02:51 AM   #39
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Generally yes we will install an oil interceptor for commercial if the drain is hooked to city services. Residential usually is not hooked to city so not in that situation. Depends on project really.
MeanWeen is offline
Old 11-12-2017, 06:53 AM   #40
B.Johnson's Avatar
Trade: Builder
Rewards Points: 504
I have never understood why it is that if you have a drain you need an oil separator, but you can force it out of the door and into the ground and that is ok.
Home Designer Series Software
B.Johnson is online now
Tags
frame , slab , slope , wall
Framing Layout and Blueprint Reading - Seeking Advice and Tips for Beginners Workin Kid Framing 49 02-27-2013 12:54 PM
Walls before slab VAviaCo Framing 14 07-15-2012 10:23 PM
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 11:45 AM
24" on center framing on exterior walls lunapark Framing 9 09-13-2009 11:53 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
