Framing Walls On A Sloped Slab - Carpentry - Contractor Talk
Old 07-26-2017, 11:15 AM   #1
Syner's Avatar
Trade: VS Woods
Rewards Points: 24
Typical detached garage slabs are poured with 2-4" of slope in my area. Some have curbs, most don't.
I've seen a lot of framing methods addressing the slope (I have my preferred approach) and was curious what you all do.
Method I use:
I've found the most accurate and time- (re: cost-) effective method for myself is measuring with a surveyor's level every 12", drawing the slope in CAD, then printing out a numbered cut list for my helper (I am marking plates while my helper cuts).
Some of the other methods I've seen:
- Completely ignore the slope. Frame a square wall and let the garage lean into the alley. - The individual doing this in my area undercuts everybody by ~75%
- Cut a full length shim out of 6x PT material (essentially creating a level curb) - I've only seen one guy do this. I like that you don't have to cut individual studs, and it raises untreated material even further from grade. I don't like needing 6"+ anchors on the more extreme slopes.
Methods I've read:
- Erect: Stand the ends and mark the tall side with a string level. Toe-nail studs, snap a chalk line, and cut each in the air.
- On the ground: Measure the overall slope and cut the tall stud accordingly. Lay interior studs, snap a line, and cut each. (Very similar to my approach, minus a pre-calculated cut list).
So, what's your preferred approach?
Syner is offline
Old 07-26-2017, 11:20 AM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,296
Re: Framing Walls On A Sloped Slab
I had always used the fourth method you mentioned. On the ground.
Andy.
ScipioAfricanus is offline
Old 07-26-2017, 11:42 AM   #3
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 12,134
Your precalculated cut list is pretty cool. I've ran a string at corner height, then measured to the string , and then framed my wall.
A&E Exteriors is online now
Old 07-26-2017, 08:13 PM   #4
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
you're basically framing an upside down rake wall...calc or snap n cut... whatever makes you more comfortable
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following 2 Users Say Thank You to parkers5150 For This Useful Post:
Californiadecks (07-26-2017), Rio (07-26-2017)
Old 07-26-2017, 08:53 PM   #5
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 194
I pour the slab flat around the perimeter and slope the floor from about a foot inside the walls.
Doing so avoids this issue completely.
jlhaslip is offline
The Following 10 Users Say Thank You to jlhaslip For This Useful Post:
A&E Exteriors (07-26-2017), Californiadecks (07-26-2017), Dirtywhiteboy (07-27-2017), hdavis (07-27-2017), J.C. (08-10-2017), Rio (07-26-2017), ScipioAfricanus (07-27-2017), Syner (07-26-2017), Workingmanvan (07-30-2017)
Old 07-26-2017, 09:07 PM   #6
Syner's Avatar
Trade: VS Woods
Rewards Points: 24
I wish I had that luxury. Unfortunately, the vast majority of garages I build are on pads poured by cookie-cutter home builders. They will pour level perimeters for a cost - but most homeowners don't understand the point/benefits of it.
Syner is offline
Old 07-26-2017, 09:44 PM   #7
GC/carpenter
Californiadecks's Avatar
Rewards Points: 4,534
That's why you explain to the home owner that it's more expensive to not pour the slab with level perimeters due to fact that it's easier to form than frame. A little home owner education goes a long way in this business. Communication is key!
Mike.
_______________
Californiadecks is offline
The Following 4 Users Say Thank You to Californiadecks For This Useful Post:
NJGC (11-10-2017), overanalyze (07-26-2017), Rio (07-26-2017), ScipioAfricanus (07-27-2017)
Old 07-26-2017, 10:58 PM   #8
Syner's Avatar
Trade: VS Woods
Rewards Points: 24
Mike.
_______________
I couldn't agree more.
Unfortunately by the time most homeowners contact me, they've signed off with their home builders and hefty penalties accompany any alterations.
Syner is offline
The Following User Says Thank You to Syner For This Useful Post:
hammer7896 (07-27-2017)
Old 07-26-2017, 11:42 PM   #9
GC/carpenter
This is one reason I NEVER enter into sub contracts. I'll only take prime contracts. I need to be the keeper of the gold.
Mike.
_______________
The Following 2 Users Say Thank You to Californiadecks For This Useful Post:
decksterdecks (08-15-2017), NJGC (11-10-2017)
Old 07-27-2017, 11:07 AM   #10
hdavis's Avatar
Rewards Points: 3,919
Simple slope, I measure the drop and gang cut the studs, after first "squaring up" one end to account for the drop, and then cut the other end square. No miter saw, just a circ saw. Nail together and stand it up.
How the wall gets attached to the slab can make a big difference in cost.
hdavis is online now
Old 07-27-2017, 11:13 AM   #11
hdavis's Avatar
If you're marking each stud and then cutting, string a chalk line between the corners at the right height, then take each stud, set it each in place, mark with the chalk line, then cut them all and toe nail.
Working alone, this is easiest and fastest to cut on the ground, IMO
Old 07-29-2017, 12:07 AM   #12
Workingmanvan's Avatar
Trade: Carpenter-Renovations/Repairs
Rewards Points: 276
If it was my own place I would build a curb and put the walls on that. Other than that, my first thought would be to rip shims for under the plates, depending on how severe the slope was.
Workingmanvan is offline
Old 08-07-2017, 07:35 PM   #13
Rewards Points: 746
The method we use is to shoot control points at all corners, cut the studs for those corners so that the tops of them are exactly the same level.
Then run a chalk line from top to top, mark each stud to the line and cut. Perfectly level, very fast, and dead on accurate.
The pictures are from 2007, man I've aged!
Timuhler is offline
The Following 4 Users Say Thank You to Timuhler For This Useful Post:
A&E Exteriors (08-07-2017), ACEVEDO (11-13-2017), hdavis (08-07-2017), Syner (08-09-2017)
Old 08-07-2017, 09:28 PM   #14
hdavis's Avatar
So you mark them in place, then cut on the floor? Gang cut?
Old 08-07-2017, 09:32 PM   #15
Rewards Points: 746
Nope we just cut them, nail the plates on and lift the wall
Timuhler is offline
The Following User Says Thank You to Timuhler For This Useful Post:
hdavis (08-07-2017)
Old 08-09-2017, 11:35 PM   #16
Syner's Avatar
Trade: VS Woods
Rewards Points: 24
So if I understand correctly, you lay your bottom plate and brace the ends, mark and cut each stud, then build the wall on the floor? Or are you toe-nailing each stud?
Syner is offline
Old 08-09-2017, 11:38 PM   #17
GC/carpenter
The chalk line applies the mark in the air. I like it!
Mike.
_______________
Old 08-10-2017, 08:30 AM   #18
hdavis's Avatar
Doing it that way, you don't toe nail.
A few months ago I watched a guy toe nail them all in standing up and then put the top plate on in place. Not my idea of a good time.
Old 08-10-2017, 12:07 PM   #19
Syner's Avatar
Trade: VS Woods
Rewards Points: 24
That's exactly what I was thinking.
Based on the replies in this thread, it seems like marking with chalk is a favorite. Maybe I'll forego my pre-calc'd cut list on the next sloped pad - at least it'll save an extra trip to a site.
Syner is offline
Old 08-10-2017, 12:23 PM   #20
J.C.'s Avatar
Rewards Points: 1,680
I've never had to do it but, I think I'd probably use a laser level to calculate the slope and construction master to tell me the stud lengths.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
The Following User Says Thank You to J.C. For This Useful Post:
Stilla (11-11-2017)
Tags
frame , slab , slope , wall
Framing Layout and Blueprint Reading - Seeking Advice and Tips for Beginners Workin Kid Framing 49 02-27-2013 12:54 PM
Walls before slab VAviaCo Framing 14 07-15-2012 09:23 PM
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 10:45 AM
24" on center framing on exterior walls lunapark Framing 9 09-13-2009 10:53 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
