Framing/ Remodeling
Old 10-30-2009, 08:22 AM   #1
mencheman
mencheman's Avatar
Trade: General
Framing/ Remodeling
good morning
I am a looking to remove a load bearing wall carrying the attic space floor joist ,
it is essentially a crawl space attic, just hvac and duct work
the joist are 2x6 splice over the 2x4 load wall and then another continuous run has a header in the attic a 2x12 resting on the corner post and perimeter wall carrying 2x8 toe nailed
My question is i want to replace all with a 3x12 LVL by Louisianna pacific
run it from the perimeter walls to a load beaing post carried through to the cellar.
Can i use teco hanger and nail into the side of this LVL and where would i find the load bearing capacity.
mencheman is offline
Old 10-30-2009, 08:26 AM   #2
AJAX's Avatar
Trade: GC, Remodeling
Re: Framing/ Remodeling
Your millwork guy should know the engineering specs. for all that.
AJAX is offline
Old 10-30-2009, 09:38 AM   #3
KentWhitten's Avatar
You need an engineer to look at this. Don't mess with structure and assume it will be fine. If it fails you are liable for everything. Don't mess around with this.
Salmon Falls Cabinetry
KentWhitten is offline
Old 10-30-2009, 08:16 PM   #4
remodeler
RobQuillin's Avatar
Trade: Residential Building Contractor
I have always gone to my supplier and explained what I wanted to do. They will run the engineering specs on the LVL's and tell you the load points and even the hangers and how to connect the LVL's together.
RobQuillin is offline
Old 01-09-2010, 08:54 AM   #5
royceGC's Avatar
Knowing the specs of the beam is only half of the equation.
The other half is knowing the CALCULATED LOAD of what the beam is holding up (ceiling load + any roof loads bearing upon it).
The presence of ducts etc has little to do with anything, as they would already be considered within the standard floor load calculations...unless there is an extreme weight condition...ie: bath tub, heavy equipment.. Check with an architect, engineer or draftsman for actual calculations as there are no shortcuts on this one.
"That's plenty big" is not a calculation!
royceGC is offline
Old 01-10-2010, 08:51 AM   #6
General Contractor
greg24k's Avatar
Hire an engineer or an architect, before you do anything with load bearing partitions.
greg24k is offline
Old 01-10-2010, 09:23 PM   #7
galla35's Avatar
exactly hire and engineer and make sure your butt is covered
galla35 is offline
Old 01-15-2010, 01:56 AM   #8
Lark and Lark's Avatar
Trade: United Kingdom
I think you need a professional engineer dont try it your self or you will be messed up.
Lark and Lark is offline
Old 01-15-2010, 03:12 AM   #9
Teetorbilt's Avatar
Moving/changing a load bearing anything requires a permit and inspection here.
Albert Einstein
Teetorbilt is offline
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 11:45 AM
Framing Safety Safety Guy Tools & Equipment 3 08-13-2009 09:46 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 06:11 PM
Siding, Framing, and Remodeling Expert in houston area seeks work DK's Siding Help Wanted or Looking For Work 0 04-01-2009 08:32 AM
