Framing For One Piece Tub/shower Unit
Old 07-20-2012, 06:56 PM   #1
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
I was installing some of these in a remodel today and was wondering how others do this. I usually notch my studs so the screw flanges sit flush with the framing, makes it easier on the drywall guys. I know it's not always possible to do this...you have to have the tub in place before you put in the final wall.
I have sometimes nailed furring strips to bring the framing out flush . I'd like to hear some discussion.. is it any advantage to you drywall guys? Should drywall even go down over the flange?
Brian Peters is offline
Old 07-20-2012, 07:36 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,432
Re: Framing For One Piece Tub/shower Unit
brian i am a little lost with your post, one piece/ flange?, drywall in wet aera?
sunkist is offline
Old 07-20-2012, 07:44 PM   #3
Rewards Points: 972
Yes..one piece, this one today was Delta brand. Here in Kentucky these are quite common...and yes they put drywall around them.
This is what I'm wanting to hear...discussion from other places, hoping I learn a few things :-)
Old 07-20-2012, 07:48 PM   #4
Rewards Points: 972
This is what I'm talking about
Old 07-21-2012, 01:05 AM   #5
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
we just frame the opening. dry wall goes over the flange, then some trim.
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
Old 07-21-2012, 01:15 AM   #6
Dirtywhiteboy's Avatar
Rewards Points: 7,964
I'm with BigB. we just frame it, Those things are usually 5' here. Frame it 5'1/4"
Dirtywhiteboy is offline
Old 07-21-2012, 03:15 AM   #7
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
I've used the furring strip method and in similar types of situations rasped the backside of the drywall.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
The Following 2 Users Say Thank You to moorewarner For This Useful Post:
kambrooks (07-21-2012)
Old 07-21-2012, 10:33 PM   #8
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
The drywall guys dont matter. Its the carpenters that need to deal with the curve!
Yes, every adjacent wall "should be" shimmed out. But most times, because of cost or laziness, they aren't.
I still use greenboard/purpleboard when painting the rest of bathroom. Would use cement board if tiling. Some use the fiberglass board...
Guilford, CT Remodeler and Carpenter Web-site Twitter@CraftsmanJay
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 07-21-2012, 10:40 PM   #9
Rewards Points: 538
Oh, notching is fine too. But i never bothered, seemed like more work. You know what you're doing. Don't over think it.
Facebook
Old 07-21-2012, 10:43 PM   #10
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
I just hack out the back of the drywall.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
griz (07-21-2012)
Old 07-21-2012, 10:51 PM   #11
slowsol's Avatar
Rewards Points: 2,212
Everyone I've ever seen, the drywallers stop their board at the flange and hot mud/tape over the flange.
-John
slowsol is offline
Old 07-21-2012, 10:58 PM   #12
Fire up the BBQ
griz's Avatar
Rewards Points: 468
Most common way I have seen the issue dealt with...
griz is offline
Old 07-22-2012, 04:27 PM   #13
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
Well if it is a one piece no ceiling i notch the studs. If it is a one piece with ceiling i'll just ad backing inside the framing and set it back the thickness of the tub flange.
CanningCustom is offline
Old 07-22-2012, 04:33 PM   #14
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I have done this many different ways including all the above. Last year we did one where the drywaller installed 1/4 over the flange and then mesh taped the whole kitten caboodle. I thought it turned out nice.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
CanningCustom (07-22-2012)
Old 07-22-2012, 04:37 PM   #15
txgencon's Avatar
Rewards Points: 430
I believe it's the builder's job to see that the walls are firred out. Sometimes, that's three walls in a 5x10 to 5x12 room. Whatever it takes.
The framer is long gone.
I don't really want the plumber hacking on studs.
I certainly don't want the rock hanger hacking the back of the drywall.
I've seen houses where there wasn't any consideration given to the offset created by the thickness of the flange. Looks like crap.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 07-22-2012, 04:39 PM   #16
Especially when the walls are tiled.
Old 07-22-2012, 05:00 PM   #17
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
I always fur the walls out the 1/4" it needs to match. That way its all ready to go.
mnjconstruction is offline
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 10:45 AM
Mold growth on framing? jhark123 Business 24 03-17-2009 02:24 AM
European Certified Rough / Framing / Roof Carpenter TimberRoofFrame Help Wanted or Looking For Work 0 03-09-2009 10:37 PM
Framing Knee Wall with Metal Studs arawas Framing 6 02-18-2009 07:03 PM
odd Goodman package unit problem airwick HVAC 3 07-17-2008 10:36 PM
