Framing Arches
Old 05-02-2015, 04:44 PM   #21
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Re: Framing Arches
I have been doing arches like this for years. Don't know if this is still the way it's done.
Attachment 175778
wallmaxx is offline
Old 05-02-2015, 04:53 PM   #22
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
Re: Framing Arches
What manner of sorcery is that???!!
digiconsoo is offline
The Following User Says Thank You to digiconsoo For This Useful Post:
wallmaxx (05-02-2015)
Old 05-02-2015, 06:00 PM   #23
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Framing Arches
So:
where S= the Span of the opening
where R= the Rise from the chord span to the top of the arch
Radius = (S^2 + 4R^2) ÷ (8R)
But that just makes it part of a circle. An ellipse/parabola is different entirely....unless you're framing for a math professor (like I did for a Rice U math prof once) you can eyeball half of it and flip it over to keep it symmetrical.
The RPN way is way more fun.
wallmaxx is offline
Old 05-03-2015, 11:25 AM   #24
kiteman's Avatar
Rewards Points: 16
Re: Framing Arches
The framing method is what I do but I don't recognize the formula
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 05-03-2015, 02:08 PM   #25
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Framing Arches
Ellipse is like this:
wallmaxx is offline
Old 05-05-2015, 09:12 PM   #26
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,399
Re: Framing Arches
Ellipse have 2 vertex not centre. And radius of ellipse is sum of distance from 2 vertex if I remember correctly.
tipitop is offline
Old 05-05-2015, 11:33 PM   #27
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Framing Arches
Correct. Two foci.
wallmaxx is offline
Old 05-06-2015, 10:37 AM   #28
hdavis's Avatar
Rewards Points: 8,131
Re: Framing Arches
An ellipse has 2 foci. For the special case where they are coincident, the ellipse is a circle. The radii are frequently said to be the two semimajor axis, although mathematically this is imprecise.
In any event, if you are thinking the "radius" is the sum of the two semimajor axis, this is obviously wrong, as the special case of a circle makes plain.
hdavis is online now
wallmaxx (05-07-2015)
Old 05-06-2015, 01:33 PM   #29
mnld's Avatar
Trade: drywall junky
Rewards Points: 492
Re: Framing Arches
Obviously.
:sly::what:
mnld is offline
Old 05-06-2015, 06:52 PM   #30
hdavis's Avatar
Re: Framing Arches
I could put math on the things I hate thread, but it's more like an uneasy relationship.
Old 05-07-2015, 02:29 PM   #31
AustinDB's Avatar
Rewards Points: 596
Re: Framing Arches
I tripled up a piece of string to make a large 27' radius. That cut the flex down and the surface I was pulling over was smooth and flat which helped.
guess these are all different size openings and you can't use the same one
I've had a HP48GX sitting on my shelf for 12+ years-it looks cool but is confusing
AustinDB is online now
The Following User Says Thank You to AustinDB For This Useful Post:
Old 05-07-2015, 11:12 PM   #32
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Framing Arches
I bought the 48SX when I was an Aggie in 1990
Then the 48GX, 49g and now the 50g.
I was a calculator guy before the internet really took off.....they never let me down so I keep finding ways to make my calculator useful.
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
AustinDB (05-08-2015)
Old 05-08-2015, 09:51 PM   #33
Rhode Island's Avatar
Trade: Genral Contractor
Rewards Points: 264
Re: Framing Arches
I just make a template and have at it. Granted I don't do a lot, but they come out good.
Rhode Island is offline
Old 05-08-2015, 09:58 PM   #34
tipitop's Avatar
Trade: carpenter
Re: Framing Arches
With all risk to get stones throw at me again that arch is not good enough. I can se uneven lines. Compare to this arch that I build past year. Btw sheet rocker should help with his work. Maybe he mess? That second arch in background look really clean.
tipitop is offline
Old 05-08-2015, 10:03 PM   #35
Rewards Points: 264
Re: Framing Arches
I hope that wasn't directed at my arch. Maybe it's the shadows from the night pic, but they are very good. There's some serious arch to them rather than a minor bend over 6'.
Old 05-09-2015, 06:40 AM   #36
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,463
Re: Framing Arches
I hate when the top of the arch is that close to the ceiling. Good luck if anyone ever wants crown in there.
Easy Gibson
Warren is offline
Old 05-09-2015, 09:41 AM   #37
tipitop's Avatar
Trade: carpenter
Re: Framing Arches
I actually agree with you. I had talk with women before I build arch exactly about space for future crown. She said that with crown space would be to busy. When all is done I actually agreed with her. It is a lot in and out on ceiling as I had to cower air ducts.
tipitop is offline
Old 05-09-2015, 10:21 AM   #38
Geometrist
Warren's Avatar
Re: Framing Arches
Even without the regard for crown, it still looks too high.
Easy Gibson
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
C2projects (05-09-2015)
Old 05-09-2015, 03:46 PM   #39
tipitop's Avatar
Trade: carpenter
Re: Framing Arches
Yeah for my taste to. How much you would recommend space in middle for 10' of ceiling maybe something like this (but someone else frame that arch. I did only trim there). In photo is ellipse of course.
tipitop is offline
Old 05-09-2015, 03:50 PM   #40
tipitop's Avatar
Trade: carpenter
Re: Framing Arches
See what I see like problem with yours arch and for sure many would agree. It is “too curved”. That is problem for sheet rocker/ tapers. No matter how precise is your arch they will not be capable do quality work. Try to avoid short radius. I go usually to 20’ radius.
tipitop is offline
Cordless Framing Nailer Reviews KSContractor Tools & Equipment 53 02-19-2014 08:22 AM
Traditional Framing a threat to National Security Dustincoc Framing 43 08-19-2013 10:41 AM
Top 10 framing errors - and how to prevent them (From a Professional Builder Email) wallmaxx Framing 9 02-20-2012 06:57 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 05:11 PM
Framing a groin vault? denver 2 Carpentry 12 01-13-2009 12:46 PM
