#21 | |
Trade: Geotechnical PE
Re: Frame And Sheetrock An ArchQuote:
I like the pick Adam and I've seen other guys do it this way. This thing is on this job there is one existing, non circular, arch of a different size that I have to match up to. The trick is going to be to make it proportional/visually stimulating. My original thought was that if I bent plywood into the curve and blocked behind it, I could shim it in and out until the proportions seemed just right. |
#22 |
Formboard for the inside of the arch.
#23 | |
FRAME ON!
Trade: Decks,All phases of remodeling,
Read what I posted.
#24 | |
Trade: Custom deck builder
#25 | |
Trade: painter
Thanks. |
#26 |
Trade: general contractor
we use premade metal arches. any size we need. few nails and maybe 2 blocks of wood and ready for drywall. takes about 10min
#27 | |
Mod / ArchiBuilder
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
#28 |
Trade: General Contractor/Remodeler
My Dad and I use JustAFramer's method all the time. Last year we had to do a decorative rough cedar arched frieze board over a double garage door. It was a pretty shallow offset, which means you're dealing with a large circle, so we knew we'd need some space. We set up at the back wall of the garage and snapped our chalk line, anticipating a long radius.
We kept running out the two tapes and shaking our heads because the numbers wouldn't match up. They finally did - at 35 feet! We tacked a lot of scrap together to make the swing-arm for that one, LOL. It turned out beautifully in the end. Thank goodness we didn't have to construct the whole 70 foot circle. |
#29 | |
#30 |
Wetting the drywall is the way I do it as long as the radius is not to tight.
#31 |
Life-Long-Learner
Trade: Home Repair & Remodeling
I am having a hard time understanding what exactly you are doing but this is what we have used a few times to save us allot of time and money.
http://www.arch-rite.com/products.html The first time we used it we made a dome like vaulted ceiling. They have a picture that looks identical to that job on the site. I would rather get it done in less time especially if I have one of my guys working on it. Show us some pictures of the job in progress!!!
If you are afraid of criticism, you will die doing nothing. |
