I used to think so.......
Form Framing For Stone Column Caps
I helped my friend set up forms on his porch columns so he can pour 10 degree sloped concrete caps that will cover future stone wrap. I have never seen this before with concrete, but he said it was typical in FL, where he's from. I like the idea of concrete for the cap. Seems very low maintenance. Typically we just build the caps out of wood here.
Re: Form Framing For Stone Column Caps
I just love how downspouts do that over the columns.
It's interesting. It seems fine to me. Showing off your Makitas are you? I am getting ready to buy the exact same thing. They are nice!
If you correct your mind, the rest of your life will fall into place ~Lao Tzu Custom Cabinetry - Portland, Cape Elizabeth, Scarborough, Kennebunkport, Yarmouth, Falmouth, Cumberland, Ogunquit, Maine Salmon Falls Cabinetry Last edited by KentWhitten; 02-01-2009 at 04:01 PM. |
What's the material called you're forming with? Looks like plywood with masonite adhered on each side. Looks like slick stuff for forms.
Trade: Carpentry & Remodeling
Its MDO, medium density overlayment. Usually used on ext. applications signs etc.
I think.
Do what you would do, as if i won't Do anything after you Did It! |
Re: Form Framing For Stone Column Caps |
I could be wrong,, is their a HDO, high density overlay??
Armorboard, cool i wonder if that would be a special order deal. Iknow masonite doesnt hold up too well to weather though right?
Trailer park boy
http://www.canply.org/english/produc...aidplywood.htm
http://www.insidewoodworking.com/lum...o-plywood.html http://www.mccauseylumber.com/ppcfp.html
"Industry without art is brutality"
| The Following User Says Thank You to shanekw1 For This Useful Post: | greg24k (03-15-2009) |
Palisade Point Const.
I've built forms for a concrete cap on a chimney before. It seems like you would want to finish the caps like concrete counter tops when it's right at eye level though.
A big wannabe
Trade: Framing, decks, trim, Remodels, ground up.
Nice jobsite radio!!! You guys like to break into a freestyle dance while your working?
"Check it, this form was put on by...... 'the robot'!" LOL. |
Hard to tell on this monitor,
Could be HDO (AKA, architectural grade). Used a lot for form work on commercial work, especially slip forms, columns, stuff that is reused a lot.
I wonder what the price diff would be between that and melamine? I'm sure melamine wouldnt hold up as well though for repeat applications.
If you made me guess, I'd guess not much at all. I hope Walmaxx reposts. He might just say it was scraps they had leftover and thought they'd use them up here.
It's 1" thick (3/4" CDX plywood with 2 layers of the peg board type material laminated on each side.) The HO / builder got them from someone for free. They were all 4' x 5' (and very heavy) Some had circle cut outs along an edge, so I think they were for forms at one time. Maybe you can see the notch outs in this photo.
It looks like good stuff, i'd like to try it.
The music is a must.
I busted my DeWalt radio...so I revived my sound system from my old BOOM car days and power it with a 100 watt RMS per channel Yamaha home receiver into an MTX Terminator box. A bit loud...but real c-l-e-a-n. |
#18 |
Trade: siding
so your wraping the post in concrete?
#19 |
The top gets a kind of Azek but off brand. Then the concrete cap (black dye to match the concrete deck). Then under the caps, wire mesh attached to the PT plywood for the mortar and finally synthetic stone to the mortar base.
The HO is a stone guy...he'll do good work. |
| Bracing pyramid hip framing please help. | TurnkeyConst | Framing | 15 | 06-24-2011 11:30 PM |
| Licensed and Regulated Framing?? | wallmaxx | Carpentry | 17 | 01-05-2011 09:56 PM |
| Mold growth on framing? | jhark123 | Business | 24 | 03-17-2009 03:24 AM |
| framing fire place opening | Marcus1 | Framing | 2 | 09-16-2008 09:28 PM |
