Floor Joist Out To Deck?
Building second story. I want the floor joist to cantilever out for the deck joist using womanized material. Anyone see a problem with this?
Mod / ArchiBuilder
Re: Floor Joist Out To Deck?
Not as long as you have the proper support for the deck.
How far are you going to cantilever it off of the second story?
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Charitable animal
Trade: decks
Re: Floor Joist Out To Deck? |
Actually I used the word cantilever but the reality is their will be support beam and post. I know the 25% ration on cantilever, I am concerned with the sealing of the house. Is their a problem with the deck and the second floor sharing joists?
Thanks |
#5 | |
Charitable animal
Trade: decks
Re: Floor Joist Out To Deck?Quote:
Mod / ArchiBuilder
Chris, I agree with you.
Trade: Custom deck builder
If your going to have a beam and posts anyways dont run your joists into the house at all. This way down the road when something happens and you need to replace a joist or 2 you can acctually do it. Not to mention all the blocking and flashing that was already mentioned. I see LOTS of 20-25 year old decks around here that are canted and the framing is in poor shape. They are all in desperate need of replacement but who wants to take on that job?
#8 | |
Charitable animal
Trade: decks
#9 | |
FRAME ON!
Trade: Decks,All phases of remodeling,
HEHHEHEHEHEHEH
#10 | |
#11 | |
Class A Contractor "BLD"
Trade: Remodeling and home improvements
Take this advise as being very true. Build your deck off (not attached to) the house.
Looks like some pros were here. |
#12 | |
Trade: Framing Contractor
Joe Carola |
miterclamp.com
Trade: interior trim/cabinets
Well, Irving, if the previous 7 opinions don't sway you, I will eighth those motions.
The bid is now 9; Going...... Going.............. Regards, jimc |
Another little 'tid-bit', - - far as I know, - - if you ever have a 'house-fire' the P.T. wood is highly toxic, - - so that's another reason you wouldn't normally use it in your 'application'.
http://www.tr-built.com |
#15 | |
HouseWright
Trade: Designer/Builder
But, all kidding aside, I agree with the mob here (which is rare for me). If the deck isn't "really" cantilevered then there is less than zero reason for building it that way. Air leaks, water leaks, rot problems, future renovation and repair issues... In fact, building the deck "off" the house, as someone else here said, I would take literally. Don't even attach the ledger (or the inboard railing posts) directly to the house without some kind of spacer to maintain breathing room and prevent the all-too-common moisture/rot problems down the road in the house framing/sheathing. - Robert |
Trade: genaral contractor
Just Finished home with cant. deck Problem is door inside to deck outside has no NO room for threshold therefore snow ice rainwater etc is going to be leaking into house deck is on 2nd story with sliding glass door no head room to raise door nor would in my opinion look pretty stupid to have a 8' sliding door 7" off the bedroom floor .
If you do decide to cant. deck make sure to use smaller lumber than house floor joist meaning 2x12 floor joist 2x8 cant joist For deck (etc)at least you will have a step down to deck instead of even floors like im dealing With Good luck Personally I think Its A waste of Money and bad idea to cant. deck |
Plumber / Carpenter
Save head achs, if you cant into the house you have opened yourself to leaks, me? I'd run a ledger and lag it to the band then tie into it with my joists and joist hangers, myself have seen many canted jobs that have leaked and owners had to spend a whole lot more to replace all the damage.
#18 |
I'm going against the mob here. I put a 4' X 15' balcony off my master bedroom and cantilevered it. The posts would have ruined the design of the house. I don't have any problems with water either.
#19 |
Do it Right, Do it Once
Trade: Deck & Concrete
Asking for problems. We refinish decks, lots of decks and we see all kinds of bad things. you know how dry rot things are, often by the time you have an idea that something is wrong, it's really bad under the surface. Some of the new houses are the worst for doing inproper flashing..... There are too many builders that make it look good, but don't really do what it takes to seal and flash. I don't know how they get away with it, but about 25% of the new homes, the ledger is only nailed, not lagged. I don't understand how they get a final.
We just did a job where the builder used Non PT wood and painted it. Take a look, only 4 years old. |
| Used the new Correct Deck CX-personal review | IHI | Decks & Fencing | 22 | 07-27-2008 09:52 PM |
| Correect Deck ?'s Robert and others | IHI | Decks & Fencing | 9 | 05-21-2008 10:45 PM |
| Deck Building Question | brewsterb | Decks & Fencing | 2 | 06-21-2007 01:29 AM |
| Dry lower deck stuff | frostyfrost | Decks & Fencing | 12 | 05-19-2007 07:59 AM |
| Cedar Deck Prep Problems | Larman | Painting & Finish Work | 2 | 05-04-2007 05:31 PM |
