Trade: joinery business
Fitting Door Hinges Jig Or Chisels
Im new from scotland so terms might be diffrent doing alot of we job
recent and im fitting doors for people, so every door is difrent butt hinges usualy the same design and size and never used a hinge jig so is it worth trying to get used to or a waste of time. |
Re: Fitting Door Hinges Jig Or Chisels
Get a jig for sure. Faster and cleaner.
Trade: carpentry
jig
Jigs will make you happy.
Professional Remodeler
For one door I will use a chisel, but two or more makes it worth getting out and setting up the jig. You won't be sorry you took the time to learn, especially with multiple doors.
-Mike- Falcon Contracting Residential - Commercial
Trade: Replacement Windows and Doors. Trim Carpentry and Decks
Hey guys... I 've been thinking about getting a door jig for a while. So far the most common ones that I find are the Porter cable and the Bosch kit. Any imput as to which one is prefered or if there are other kits that do well?
Thanks _Matt |
i think it would be better to make a jig because if you use the same ones you can make for that and if your buying the hinges get the curved edges so you dont have to chisel the corner.
Trade: Cabinet builder/installer
I have both jigs( bosch and Portercable) I probably prefer the portercable, but they both work excellent. I see the new portercables come with 4 jigs in the kit, which is a must if you hang any 8' doors. Good luck
Sharp Improvements
Get jiggy with it. I use the Portercable for $20 including bit. It is fast and easy.
#10 | |
Re: Fitting Door Hinges Jig Or ChiselsQuote:
My most used is still the little black plastic PC individual jig, same as the Carey. For a couple of doors on a house, I don't think it is worth the bother to set up the multi-template jig. |
| Fitting You Into The Schedule | GregS | Electrical | 5 | 09-05-2007 10:48 PM |
| Fitting totes | JamesNLA | Plumbing | 7 | 08-23-2007 06:27 PM |
| Fitting MDF trim | Bummie | Finish Carpentry | 11 | 08-19-2007 02:28 PM |
| entrance fitting | MSSI | Electrical | 43 | 01-16-2007 10:40 PM |
| Tips on fitting beading | Mr Seal | Windows, Siding and Doors | 0 | 09-03-2006 01:25 PM |
