Finishing House Exterior
Old 03-17-2007, 10:17 AM   #1
lionhntr's Avatar
Trade: excavation
Hey everyone. I am currently starting up on a project that I left off on last fall. I am setting a prefab house on a daylight basement. I used ICF's on the foundation and set the perimeter of the foundation 2 inches outside of the prefab house measurements. I plan to cover the prefabrcated part of the house with 2 inch faom to match the foundation.
My question is, what would be the best way to finish out the windows on the existing structure? Should I fur them out and reset them to the outside of th wall? I plan to use a dryvet finish on the house so I thought that I could possibly leave the windows where they are and just finish over the outside foam into the window.
Hopefully I am not confusing everyone.
Any ideas would be appreciated.
Thanks
lionhntr is offline
Old 03-17-2007, 10:25 AM   #2
Same Old's Avatar
Trade: Residential General
Re: Finishing House Exterior
Good luck.
Same Old is offline
Old 03-17-2007, 04:49 PM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Dryvit on a wood frame house??? - Double good luck!!!!
Are you sure it is even legal where you are?
Make sure your windows are installed correctly and preferably by a certified installer. That may make it possible to have some kind of insurance coverage or guarantees in the case of moisture and mold problems.
Dick
concretemasonry is online now
Old 03-19-2007, 11:13 AM   #4
lionhntr's Avatar
Trade: excavation
OK, I was hoping it wouldn't sound like that bad of an idea. But I had a feeling it probably wasn't a good one, that's why I thought I would ask for input.
First off, Is dryvet only designed for concrete structures? I am not that familiar with it and definatly not planning the doing instalation. It was however recomended over stucco by a local carpenter who new exactly what I am doing. That being said, I thought that it would work for this application.
As far as restting the windows, it's not my only option. I can rmove the ICFs down to the ground surface and forget about adding the xtra insulation to the exterior of the existing structure. that was my original intention, but I got railed for thinking about removing added insulation and how it would be a waste of money.
Any other opinions would be appreciated, but I would very much appreciate if you would leave a little better exlplanation.
Thanks again
lionhntr is offline
Exterior house cleaning solution Norrrrrrrrrrrrm Pressure Washing 38 06-21-2011 12:45 PM
Exterior House Miller Painting & Finish Work 6 05-12-2007 11:07 AM
Face Stone on Exterior of House rwhittaker Construction 2 04-20-2007 05:09 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Exterior house painting bid problem osudave69 Painting & Finish Work 10 04-04-2006 02:17 AM
