Filling In A Sunken Living Room
Old 10-23-2006, 10:48 AM   #1
carlspackler's Avatar
Trade: Jack of most
The sunken living room is about 20 feet by 18 feet. It's sunk about 8 inches. It's on the upper floor of a 2 story walkout so it's all wood and there is space below that I'm not looking to raise the ceiling on. I'm looking for some good methods for filling this in.
MarQ Remodeling (no website)
carlspackler is offline
Old 10-23-2006, 11:48 AM   #2
Il Fissatore's Avatar
Trade: Decking
Lightbulb
Re: Filling In A Sunken Living Room
Perhaps you could set some sort of support boards and then just board over the sunken area... I figure, 6 inch boards with the six inches vertical (like joists) with a 2 inch thick board, that should cover the 8 inches of sinkage... then you can either use a finished wood and make a wood floor, or carpet over ... Hell, maybe you can even make a lil door and use it for storage!
Just a thought
Il Fissatore is offline
Old 10-23-2006, 03:00 PM   #3
reveivl's Avatar
Trade: Renovations
Subtract subfloor and finish floor and set joists in @16" oc, block the ends and middle so they can't twist. Either rip the joists to the correct depth or shim them up so the heights work out.
reveivl is offline
Old 10-23-2006, 06:49 PM   #4
Peladu's Avatar
20' x 18' x 8" = 8.89 cu yd.
Order 9 cubic yards of concrete and be done with it.
Peladu is offline
Old 10-23-2006, 09:39 PM   #5
RobertCDF's Avatar
Trade: Custom deck builder
I really hope he is joking... Being that there is a space below I highly doubt that the floor is rated for that kind of dead load.
I would use 2x8's and 3/4 T&G block the ends and center to keep them from rolling. You may need to rip the 2x8's a little bit depending upone your exact number and your new flooring.
RobertCDF is offline
Old 10-24-2006, 02:08 AM   #6
reveivl's Avatar
Trade: Renovations
Hey, Robert that's what I would have said... Oh, wait, I did.
reveivl is offline
Old 10-24-2006, 09:38 AM   #7
RobertCDF's Avatar
I know... I dont really know much so I copy and paste other posts and add a few more words. Then I look like I am smart.
I did not really read most of the posts... Just the first one so I knew what was going on. When I say pel's comment about the concrete I had to say something.
Old 10-24-2006, 09:56 AM   #8
TexasTimbers's Avatar
Trade: Building/Remodeling/Sawmilling/Blow Stuff Up Somet
Location: In the Deep South, along the West side of Northern Central East Texas
Whatever you decide don't forget to rodent-proof it. Do not leave lethal bait as a strategy though. They will smell for a while if they get in and die there.
My suggestion is to do as what has been offered as to blocking but I would use a 1 1/8" T&G Sturdi Floor over the appropriate width joist. I would also use decking adhesive on everything to prevent squeaks from developing.
If you lay the joists flat on the sunken floor use adhesive there too. If you stand them off with shims/sleepers make sure to use adhesive on each shim top/bottom etc. When I say glue EVERYTHING I mean EVERYTHING.
The last hing you want is a call back because of a stinking squeak!
TexasTimbers is offline
Old 10-24-2006, 10:57 AM   #9
Trade: Jack of most
Excellent thoughts. Thank you.
Should I run the 2x6 or 2x8 the length of the floor or break them up with a cross joist in the middle? Does it really matter?
Old 10-24-2006, 12:41 PM   #10
Joe Carola's Avatar
Trade: Framing Contractor
Carl,
Run them in one piece always if you can get the length. It's a better, straighter and easier job. One piece is always better then two and less work.
Joe Carola
Joe Carola is offline
Old 10-24-2006, 10:18 PM   #11
BULLHART's Avatar
Trade: Commercial Roofing Inspector/ Trainer
I'd joist it out with Some TJI's, deck it, then floor it.
BULLHART is offline
Old 10-26-2006, 11:29 AM   #12
Peladu's Avatar
Use wire mesh, that way the concrete will not crumble away.
Peladu is offline
Old 10-26-2006, 06:41 PM   #13
I'm a big fan of engineered joists, especially with LVL flanges (although sawn flanges are making an comeback for some reason), but I jost don't think for this small job it's justified if he is competing against other bids. They are going to lowball with cheap stick framing. Of course a good salesman, and we all must be to flourish, can use this as a seeling point, as customers today are savvy, and are not as intimidated by technology. they watch HGTV. I think HGTV is a great boon for us because an educated customer is the best kind. Weeds out alot of objections for us before we even get there.
Old 10-26-2006, 06:50 PM   #14
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Thanks for the thought to smile about!
~Matt
BreyerConstruct is offline
Old 11-24-2006, 08:48 PM   #15
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Totally agree with Bullhart. At 18' extremely difficult to get "solid" anymore. TJI's dead flat,straight,full length. Their higher cost will be more than paid for in less labor, NO PROBLEMS 6 months later when solid goes wonky and twists up etc. Just pretend it is a deck inside the hole, perimeter band it, GLUE EM,GLUE EM, hang em, GLUE & SCREW ruff sheathing. Take ur money,smile, party.
skymaster is offline
Old 12-15-2006, 10:07 PM   #16
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
I think I would run the joist perpendicular to the existing.
JustaFramer is offline
Advice with room addition and blueprints A.W.Davis Remodeling 35 03-28-2007 07:32 PM
Room to room fan dkillianjr Electrical 12 12-14-2006 01:08 AM
Room to room fan Larry007 HVAC 5 11-24-2006 01:07 PM
supply air to mech room, grille application question durham HVAC 0 05-22-2006 10:47 PM
Filling in edge cracks on hardwood floors? Frenchy Flooring 17 03-19-2004 02:27 AM
