Fiber Cement Siding (HardiPlank) Cutting Tips?
Old 11-12-2017, 06:38 PM   #21
tjbnwi's Avatar
Rewards Points: 3,436
Re: Fiber Cement Siding (HardiPlank) Cutting Tips?
I know someone who puts the CMT fiber cement blade for the TS-75 on his Kapex.
tjbnwi is online now
Old 11-12-2017, 06:51 PM   #22
SouthonBeach's Avatar
Rewards Points: 995
I like electric shears for most cuts. Can take them up on the scaffolding easily too.
SouthonBeach is offline
Old 11-13-2017, 04:30 PM   #23
General Contractor
StillRemodeling's Avatar
Trade: general
Rewards Points: 64
I got a fiber cement blade for circular saw, works great for what we are doing.
P.S. to the negative responses, i did search the site before posting, telling a client not to use the siding of their choice because it "sucks" is terrible business advice, good luck with that attitude.
StillRemodeling is offline
Old 11-13-2017, 05:27 PM   #24
avenge's Avatar
Rewards Points: 2,794
It's up to me to educate the client I simply won't use anything just because the client says so. I actually refuse to do Hardi, I don't do much exterior work so it doesn't matter to me if I don't get the job.
Hardi is popular so it's very likely that is what a client will think they want but it's not the only option.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Randy Bush (11-13-2017)
Old 11-13-2017, 07:53 PM   #25
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 962
I totally agree. All the hype with hardi doesn't make it the best product. I have see so much of it poorly installed, by so called good installers. Does not like to lay tight. I have never installed it nor do I plan to.
Randy Bush is online now
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
avenge (11-16-2017), Rio (11-16-2017)
Old 11-13-2017, 07:59 PM   #26
VinylHanger's Avatar
Rewards Points: 7,586
I've installed zillions of feet of fiber cement. Both Certainteed and Hardie. I don't like installing either anymore. Especially when the local EQ bodies are cracking down on dust.
I have removed a ton of the old LP siding. If I had to reside my place, I would go with smartside or vinyl. I am assuming the new LP siding is nothing like the old crap.
I've done a bit of stateside and it is so much easier and cleaner.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
Old 11-20-2017, 09:06 PM   #27
Artworks's Avatar
Trade: Renovations & Construction
Rewards Points: 338
Originally Posted by MeanWeen View Post
The smart side is way easier on the crew to install. Lighter, cuts better, not dusty. Not 100% sure but you wouldn’t think the firerating would be as good. Definitely better impact resistant, so if you were using a rain screen and worried about people hitting it smart side would be better. In my climate the smart side seems to move less.
All that being said we usually use the cement board as it is still a good product but half the cost where we are located. The thing that bothers me the most is that the various cement board companies seem to have inconsistent mixes or the change their formula from time to time some times for the good, some times not. Does anyone use canexel anymore? Used to use that a lot but not much anymore. I hear people talk about caulking between the joints of the cement board and smart side. Is that a common method?
I currentley am doing a job with canexel. I like it. I have put on hundreds of bundles in the last 10 or so years. never had a problem with it and have done most of it by myself.
IF IT WAS EASY, EVERYONE COULD DO IT !
Artworks is offline
Old 11-20-2017, 09:25 PM   #28
Randy Bush's Avatar
Rewards Points: 962
You must be in Canada. Last I knew Canexel can't be had in the states. Biggest problem I ever saw with it was if it was not keep covered and got wet then it would shrink.
Sent from my LG-V520 using Tapatalk
Old 11-20-2017, 10:05 PM   #29
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
I’m from Canada, the reason most people around here stopped using it was that it wasn’t as forgiving during install and the finish wasn’t holding up as well as other products. As far as shrinking it was hardie plank that was the worst.
MeanWeen is offline
The Following 2 Users Say Thank You to MeanWeen For This Useful Post:
Artworks (11-21-2017), Rio (11-21-2017)
Fiber Cement Siding question Brian Peters Windows, Siding and Doors 12 03-30-2014 02:14 AM
Production cutting fiber cement siding Windwash Windows, Siding and Doors 18 06-20-2013 03:43 PM
Fiber Cement Siding question--- enforcer Windows, Siding and Doors 12 01-13-2010 07:29 PM
suare footing pricing for fiber cement siding guardian2474 General Discussion 61 06-09-2009 06:40 PM
ring shank nails with fiber cement siding? Jer Windows, Siding and Doors 16 01-18-2009 11:58 AM
