Fiber Cement Siding (HardiPlank) Cutting Tips? - Carpentry - Contractor Talk
Old 11-05-2017, 04:53 PM   #1
General Contractor
StillRemodeling's Avatar
Trade: general
Rewards Points: 64
ive done many hardiplank siding jobs, and ive tried many different cutting methods.
Since Im here I figured I would see what other professionals opinions are for the best way to cut it. And what techniques and tips they can offer to make the best cuts.
Score and snap? Electric shears? jigsaw with carbide coated blade? circular saw with hardi blade?
Weve used a chop saw with an old blade before and just swap out for another old throw away when it gets bad, but it creates a ridiculous ammoount of dust. but its fast and leaves a good cut.
never been able to get the shears to leave a clean cut, maybe a technique you found that will help me?
havent tried the jigsaw blade or an actual hardi blade for circular saw.
Any suggestions are much appreciated, id like some advice before spending money on a new tool or expensive blade for next siding job.
StillRemodeling is offline
Old 11-05-2017, 06:52 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,735
Re: Fiber Cement Siding (HardiPlank) Cutting Tips?
We have used the Dewalt fiber cement blades. Still a good bit of dust, but the blade lasts a long time. We previously tried some cheaper fiber cement blades, but they never last. Not sure if they still make the Dewalt ones, but I think they were about $50 or $60.
For notches, we just use a regular jig saw blade, and change it when it gets dull.
Easy Gibson
Warren is online now
Old 11-05-2017, 07:30 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,378
Where is Tom? He would say a track saw and dust collector. After a blade change it can then cut your ham sandwhich
The Hardi saw blades work pretty good I have found.
Peter_C is online now
Old 11-05-2017, 07:38 PM   #4
tjbnwi's Avatar
Rewards Points: 5,500
I'm here...
TS-55 with CMT fiber cement blade.
Change blade---pfffttt, I wouldn't even bother wiping it off. Little fiber in the meal.
fiber cement siding (HardiPlank) cutting tips?-img_3132.jpg   fiber cement siding (HardiPlank) cutting tips?-img_3133.jpg
tjbnwi is online now
Peter_C (11-05-2017)
Old 11-05-2017, 07:43 PM   #5
avenge's Avatar
Rewards Points: 3,238
My suggestion is to stop using Hardi it sucks.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
overanalyze (11-11-2017), Randy Bush (11-05-2017)
Old 11-05-2017, 08:14 PM   #6
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,634
We use the bullet tools cutter and a shear for dust free cutting. I have found that the shears cut better from the back side. If you are going to use a saw, the hardi blades are worth the price.
http://www.bullettools.com/
Home Designer Series Software
B.Johnson is offline
Old 11-05-2017, 10:06 PM   #7
Mordekyle's Avatar
Rewards Points: 3,836
Malco guillotine and shears
Dustless
Mordekyle is online now
Old 11-10-2017, 09:52 PM   #8
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
We usually use a big Guillotine and a angle grinder with a diamond blade.
MeanWeen is offline
Old 11-12-2017, 09:01 AM   #9
jstanton's Avatar
Trade: carpentry
Rewards Points: 212
Irwin Hardi blades in chop and table saw hooked to vac.
Electric sheers on the staging to get up the gables.
Carbide blades in multi tool & jigsaw.
I have the siding snap cutter but its too slow and tough to get square cuts. It also snaps the end of the cut so the siding has to be cut face up with the bottom toward you.
jstanton is offline
Old 11-12-2017, 02:34 PM   #10
Peter_C's Avatar
What is your recommendation? I most likely have a job coming up this spring residing, with new windows. Always open to using better products.
Old 11-12-2017, 02:55 PM   #11
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,469
Here we go! Why not ask what is the best oil to run in your truck is...or for that matter what’s the best truck? (you’re going to get a billion answers and this has been rehashed half a billion times.)
Let me give you some practical advice. Go get a fiber cement blade, put it on regular circular saw and try that. If you’ve been using regular blades all this time you’re gonna be in heaven. Whatever you do don’t spend $500 on Malco tools for one job until you try the Hardi blade.
They really do last a very long time. The last one that I bought survived 23 square of hardy siding plus I’ve still got it in the truck having done a dozen or so chimneys and Gables. I like the red one from HD. (Now I’m gonna get screamed at for referencing the big orange store)
WBailey1041 is offline
Old 11-12-2017, 03:26 PM   #12
Peter_C's Avatar
I already have a fiber blade for my SCMS with dust collection and my Festool track saw. I am covered. No way would I rip fiber board of any kind without dust collection.
What is wrong with asking for an opinion on which siding to use? Or which engine oil for that matter. If it has been asked a billion times, how about offering a link to a informational thread? I have worked with Hardi and it seems okay to me, but...I also respect other peoples opinions, and one of the great things about this forum is that most of us can learn from others.
Old 11-12-2017, 03:46 PM   #13
B.Johnson's Avatar
Trade: Builder
Or you could use the search feature. For best results do a Google Site Search.
Old 11-12-2017, 03:46 PM   #14
avenge's Avatar
LP Smartside you can thank me later.
The Following User Says Thank You to avenge For This Useful Post:
Peter_C (11-12-2017)
Old 11-12-2017, 04:07 PM   #15
Designer/Contractor
Rio's Avatar
Rewards Points: 2,932
So the LP Smartside website says it's lighter and stronger, both of which sound good, is easier to work with, also good, but having trouble comparing how fire resistant it is compared to fiber cement siding. This is a huge deal out here, I'm guessing it's more like regular wood in that respect but not sure.
P.S. Also says the LP is more impact resistant.
Rio is online now
Old 11-12-2017, 04:41 PM   #16
tjbnwi's Avatar
I'm a fan of SmartSide. I do think they need to do a texture/smooth trim.
"Fire resistance. LP SmartSide siding qualifies for use in California’s high fire hazard zones, as specified by the strict California building code."
From the link below;
https://www.upsidetosmartside.com/bl...-the-question/
Peter_C (11-12-2017), Rio (11-12-2017)
Old 11-12-2017, 04:41 PM   #17
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
The smart side is way easier on the crew to install. Lighter, cuts better, not dusty. Not 100% sure but you wouldn’t think the firerating would be as good. Definitely better impact resistant, so if you were using a rain screen and worried about people hitting it smart side would be better. In my climate the smart side seems to move less.
All that being said we usually use the cement board as it is still a good product but half the cost where we are located. The thing that bothers me the most is that the various cement board companies seem to have inconsistent mixes or the change their formula from time to time some times for the good, some times not. Does anyone use canexel anymore? Used to use that a lot but not much anymore. I hear people talk about caulking between the joints of the cement board and smart side. Is that a common method?
MeanWeen is offline
The Following User Says Thank You to MeanWeen For This Useful Post:
Rio (11-16-2017)
Old 11-12-2017, 04:44 PM   #18
tjbnwi's Avatar
I back flash at the seams, prime and paint the ends, no caulking.
Old 11-12-2017, 06:20 PM   #19
Designer/Contractor
Rio's Avatar
The warranty seems a little sketchy on the smartside. It's a 5/50 with full replacement for the 5 then prorated after that. 5 years isn't very long construction wise......
Rio is online now
Old 11-12-2017, 07:25 PM   #20
kixnbux's Avatar
Rewards Points: 1,440
I use a cmt fiber cement blade on my 20v dewalt miter saw. Throw another same size blade in my tablesaw. I don’t bother buying a 10”. Just the small size runs in either for that thickness of material. Makes a massive difference in dust if you haven’t tried it before
kixnbux is offline
Fiber Cement Siding question Brian Peters Windows, Siding and Doors 12 03-30-2014 02:14 AM
Production cutting fiber cement siding Windwash Windows, Siding and Doors 18 06-20-2013 03:43 PM
Fiber Cement Siding question--- enforcer Windows, Siding and Doors 12 01-13-2010 08:29 PM
suare footing pricing for fiber cement siding guardian2474 General Discussion 61 06-09-2009 06:40 PM
ring shank nails with fiber cement siding? Jer Windows, Siding and Doors 16 01-18-2009 12:58 PM
