Fastening Cabinet Boxes Together...?
Old 08-05-2009, 12:28 AM   #1
S Winklepleck's Avatar
I've heard a little of this and a little of that when it comes to joining the plywood together for cabinet boxes. Is it worth it to invest in a corner stapler, or is that a cheap a$$ way to do it? Should I just glue and clamp the holy hell out of them and not use fasteners? What do you guys think?
(either way, I'd glue them, just wondering if you guys recommend fastening or just clamping and letting the glue dry?)
-Steve
"I need the skilsaw." ... "Why did you bring me the drill box?" "It says S.A.W. on it." "Those are my initials."
S Winklepleck is offline
Old 08-05-2009, 07:41 AM   #2
Jeremy E's Avatar
Trade: carpentry
Re: Fastening Cabinet Boxes Together...?
Glue & screw wherever screws won't be visible... There are about 100 ways to do it if the screws can't be hidden. It depends on whether you're building the Yugo or the Cadillac...
Jeremy E is offline
Old 08-05-2009, 05:42 PM   #3
D.Foster's Avatar
Trade: Carpentry & Remodeling
Glue and pocket screws is strong as hell for cab boxes, then you have no clamp time.And you can reinforce the pocket screws with biscuits in between holes.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 08-05-2009, 07:28 PM   #4
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Old school staple gun. 7/16" crown x 1 3/4" length.
Thats our work horse.
Then all other kinds for things that show. No fasteners through a finished face is our goal.
Gus Dering is offline
Old 08-05-2009, 10:13 PM   #5
Well we're going for something a little nicer than a caddy, but our expectations are not much higher than that. We're going to add skins so the sides WILL get covered. I guess screwing would be ok, I've just never had a lot of luck with screws not splitting the plywood and causing ugly bumps inside the cab.
Pocket screws on the box? How's that work?
We tongue and groove all the panels, and we use 1/2" prefinished birch... so I don't see where pocket screws would work. We do use them for the face frames, though
-Steve
Old 08-05-2009, 11:48 PM   #6
Trim40's Avatar
Trade: Guy who plays with wood
I cut a 1/16th" deep dado in my face frame stock and pocket screw the boxes to the face frames.
Trim40 is offline
Old 08-06-2009, 01:30 AM   #7
we do a 1/4 x 1/4 dado in the face frames for the tongue in the side and top/bottom panels to slide into and glue it
-Steve
Old 08-06-2009, 07:03 PM   #8
D.Foster's Avatar
You can pocket screw through the bottom side of the bottom panel to the side panels, back side of the back panel to the sides, and the tops of the box to the sides, and all will be concealed. I have done this alot in the past.
D.Foster is offline
Old 08-07-2009, 09:28 PM   #9
D.Foster's Avatar
Well,.. sounds like you've already got it figured out then right?????
D.Foster is offline
Old 08-07-2009, 09:54 PM   #10
D.Foster's Avatar
I don't get it.. You have asked for suggestions, then when given,.. you proceed to explain how you usually perform the task?? When asking for help one is usually looking for a way that is unlike their own
D.Foster is offline
Old 08-12-2009, 04:29 PM   #11
Trust but verify
atnas's Avatar
Trade: Instructor & Finish Carpentry
Make sure whatever method you use that the fastner holes will not show through your "skins". I.E. thin veneers will not bridge the shallow depressions from fastners very well. If a thick skin then no worries, but if thin use some filler in the depressions.
If you don't have time to do it right the first time..., when will you have time to do it again?
Klaus Finish Carpentry
atnas is offline
Island cabinet install not2late Finish Carpentry 3 03-15-2009 08:10 PM
Boxes vs hawk and trowel d's Drywall 18 02-11-2009 11:27 PM
R-Value of beer boxes cleveman Business 15 01-16-2009 02:26 PM
Can-Am Flat Boxes dicksdrywall Drywall 1 11-11-2008 09:38 PM
how to best price costom cabinet work? mikeswoods Finish Carpentry 14 10-11-2008 02:06 PM
