Exterior Wall Out Of Plumb
Old 09-16-2007, 04:59 PM   #1
Recovering IT Guy
Second Look's Avatar
Trade: Handyman, Home Improvement, Kitchen & Bath Remodeling
Any ideas on how to plumb up an exterior wall? The house was built in 1925. In the first pic, you can see the chain I used to try to pull it in. Chain, cable winch, eybolt through a ceiling joist. It didn't seem to move at all, probably because the joist is attached to the top plate of the wall.
The wall leans about 2" out at the top.
Second Look home improvement www.SecondLookHome.com
Handyman and Home Repair Specialist in Rhode Island
RI Licensed Lead Safe Remodeler/Renovator, RI Registered & Insured Contractor
Second Look is offline
Old 09-16-2007, 06:03 PM   #2
Professional Remodeler
firemike's Avatar
Re: Exterior Wall Out Of Plumb
Without better pictures, I would say you have the right idea, but you need to separate the top of the wall from the ceiling joists and/or roof framing. You can do this by either looking for the nails and pulling them out, or using a sawzall and cutting them. You might have to use a prybar to separate the wood members enough to get a sawzall blade in there. Once you do that, either a good sledge or the chain ought to move it.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 09-16-2007, 06:12 PM   #3
MFWIC
Tmrrptr's Avatar
Trade: house painter
...don't forget... you've also got the fixed dimension goods on the ceiling.
Rock on the lid will prevent ext wall from coming in...
r
Tmrrptr is offline
Old 09-16-2007, 08:44 PM   #4
Carpenter/fencing
nywoodwizard's Avatar
First, are there collar ties or ceiling joist ? vaulted ceiling? Does the ridge have a sag? It looks as though the roof has pushed the walls out.If so the ridge may have to be jacked up and you must install some.Don't start pulling on anything until you know the answer.There may be other reasons as well.By you pulling on the wall with winches or whatever you may compound the problem by pushing the other side out or even cause something catastrophic.Do not cut anything, nails or lumber until you know and most important that you also know what you are doing.Be safe
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 09-16-2007, 09:41 PM   #5
Nathan Lee
LeeQuality's Avatar
Trade: Residential Framing, Trimming and Remodeling
If the roof has a ridge and the ridge is sagging, it is putting outward pressure on the wall. If this is the case, I would start by pushing up on the lowest point of the ridge, while pulling in the wall at the same time. Support by connecting both outer walls together in multiple places.
Good Luck.
LeeQuality is offline
Old 09-17-2007, 12:09 AM   #6
Recovering IT Guy
Those are some great answers. The ridge isn't sagging but the rafters were. 2x4 rafters on 24" centers in the snowbelt (Rhode Island). I cut kerfs in the rafters and sistered them with 2x8's which took most of the sag out.
The ceilings are not vaulted and there are no collar ties (yet).
There's a gap between the finished ceiling and the interior wall, so pulling the wall in isn't going to mess up any plaster work.
The house is a simple rectangular layout with a hip roof, no valleys.
Old 09-17-2007, 09:34 AM   #7
Tom M's Avatar
This is the right approach.
Tom M is online now
Old 10-14-2007, 09:37 PM   #8
Al Smith
A W Smith's Avatar
looks like the roof is projecting out those two inches as well. Be careful not to pull the wall out from under the seat cuts of the rafters. My experience has shown that once a ridge has sagged over the course of many decades it will not jack back up. think of the roof plane as a stressed skin. once it has taken a set the skin of the roof will not return to a true rectangle. even if it is ship lap 1 x 8 (I'm guessing due to the age of the structure) so when you pull in the wall you will likely have to cut back the rafter tails for an even soffit. But keep in mind there will be a slight crown from front to back due to the thickening rafter cross section at the seat cut and tail. You can hide this by crowning the gutter as well with leaders at both ends.
A W Smith is offline
hanging doors wink Finish Carpentry 34 09-15-2007 02:53 PM
Plumb Bobs JustaFramer Carpentry 18 08-18-2007 11:05 PM
anyone remember plumb doctor? alwysbencrzy General Discussion 3 11-04-2006 12:51 PM
Kitchen Utility Cabinet & Plumb Crazy Wall LI Hardwood Guy General Discussion 11 04-21-2005 06:29 AM
