#41 |
Priced In
Trade: Exiled For Life
Re: Ever Build A Stage Before?
Put a bunch of milk crated together fasten some 3/4 ply and call it good. Just joking. Though there is or was a bar in Seattle that use this set up for a stage.
#42 |
Trade: interior remodeling
Just tossing out a few possibilities--
If the decking were made of two layers of 1/2" ply(instead of 3/4) Glued together offset by ,say, 1 1/2 inches you would have a ship lap joint- T-nuts or threaded inserts could be placed into the lower side of the lap-- corresponding holes in the mating sleets top-- screws together at the seam. This will support the seams as there is no 'joist' to center. A 2x2 cleat around the out side perimeter would keep the deck in place- Like a box top.(a few screws would keep it from lifting) I'm still trying to figure out a way to easily tack the center down so it doesn't 'clap' as people walk on it. I'll be back.--MIKE--- |
#43 |
Yeah, see that's where I'm stuck trying to figure how to have a tool less system for securing the top. I don't want some band members mosh pitting on stage and tripping over the lip. Right now I have purchased 3/4" MDO and is in my shop waiting to be cut up.
The box crate idea is genius, no tools necessary. I just didn't want these guys to have to get out a cordless screw gun and zip it down. They will lose the screws or screw gun. I just know they will.
#44 |
solar guy
Trade: solar contracting
Re: Ever Build A Stage Before? |
#45 |
NAPTOWN--Those are similar to the CAM LOCKS --That would work--I didn't know where to find them.
Framerman google portable dance floors--You will see how they work. Good detective work,Nap--Very good! |
| The Following User Says Thank You to mikeswoods For This Useful Post: | naptown CR (11-14-2009) |
#46 |
solar guy
My old business partner had his degree in theater arts Went to school with Calista Flockhart He told me about them and it took my senior mind a while but I remembered what they were called
#47 |
The outside cleat I spoke of would not be a tripper--I meant for it to be attached to the underside of the decking,on the outside edge. (like the top of a shoe box)
One of these days I'm going to have to learn how to post a picture. |
#48 |
solar guy
bump
#49 |
I'll see your Bump and raise you one.
#50 |
Alright, I'm finally starting. I'm still messing with the securing issue. Rockler doesn't have cam locks or coffin lock that will work and they are the only ones around. I may have to order some.
Here's the design. 16'x8'. (2) 8'x8' sections
#51 |
Nice clean work.
#52 |
always building
Trade: general constructiion
might be a little late "started" but..., ( and this is w/out seeing your layout or knowing your dims.) i was asked to do one many years ago with the crux of the job being space availability. the stage only needed to be 12' tall so i presented the client with a design where the stage (when not a stage) was actually" Bookcase" type shelving. it was bottom hinged to the wall and would fold down when stage was needed. simple design, but met all of clients needs and exceeded expectations so i was able to charge an extra nickel for that one
| One man House build: tips needed | bnentrup | Framing | 44 | 01-23-2012 10:15 PM |
| how to build a bbq | roo | Masonry | 13 | 03-18-2009 04:50 PM |
| Want to build own home, or have shell built and finish myself, some questions... | Little | Carpentry | 18 | 03-11-2009 10:30 PM |
| 1870's Stage stop | rsss396375 | Historical Restoration | 11 | 01-13-2009 04:12 PM |
| trane 3 stage. | hf05 | HVAC | 0 | 11-03-2008 09:39 AM |
