Draft Stop Between Floors
Old 02-28-2007, 04:07 PM   #1
Thom
thom's Avatar
Rewards Points: 4,748
The IBC requires draftstopping the mid floor of a two floor building if the upper floor is 1000 square feet or greater. What do you guys use to draftstop open web trusses.
thom is offline
Old 03-02-2007, 07:13 AM   #2
homebild's Avatar
Trade: Professional Homebuilder, Plumber and Electrician---IRC Combination Code Inspector
Re: Draft Stop Between Floors
1/2" plywood.
homebild is offline
Old 03-02-2007, 07:56 AM   #3
Tom M's Avatar
Rewards Points: 5,534
IRC Sec R502.12.1 Materials
Tom M is offline
Old 03-03-2007, 01:16 PM   #4
Bob Kovacs's Avatar
Trade: Consultant
Drywall would be the cheapest/easiest solution, and was accepted last time I checked.
Bob
Bob Kovacs is offline
Old 03-08-2007, 07:06 AM   #5
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
Rewards Points: 150
I put in draft stops a couple of months ago and I just used 1/2" OSB. At the floor line between the first and second floor and another at the roof line. That's it.
In_Mexifornia is offline
Old 03-08-2007, 08:21 AM   #6
Thom
thom's Avatar
The IBC allows some "approved alternate materials." I was wondering if sheetmetal would do. My inspector says no so I used sheetrock.
The purpose of the sheetmetal would be it's flexibility in installation. It is used to cover all the open webs of the floor trusses, dividing the mid floor into separate spaces. My feeling was sheetmetal would allow some bending to allow cuts around pipes, ducts, and wires.
thom is offline
Old 03-12-2007, 01:52 PM   #7
personalt's Avatar
Trade: GC/Developer
Rewards Points: 145
If you were planning on insulationing anyway you may be able to kill two birds with one stone with Roxual SAFB, sound anntiation(somthing or other) fire batting I think it is called.
only issue is that normally comes about 3 1/2 inches thick. I think it costs me about .30 a square foot so you would be at .60 a square foot it doubling it up fills your joist. if you use drywall you may not have to do every trust but that would requiring further interpertation of the code and discussions with inspector
personalt is offline
Old 03-12-2007, 04:20 PM   #8
Thom
thom's Avatar
This is a draft stop required to divide the mid floor when open web trusses are used so no area is greater than 1000 square feet. Insulation is not an issue.
thom is offline
Old 03-12-2007, 04:33 PM   #9
SmithBuilt's Avatar
Trade: Commercial/Residental Construction
Rewards Points: 75
I'm trying to understand what you are having to draftstop. What is the code reference?
SmithBuilt is offline
Old 03-12-2007, 04:57 PM   #10
Same Old's Avatar
Trade: Residential General
Rewards Points: 250
I think he's referring to an enclosed space over 1000 sq ft. It needs to be seperated into spaces less than 1000 ft with a draft stop.
IRC 502.12
Skinning one truss before it's laid up w/ 1/2 rock works great. (Make sure it's straight)
Without the draftstop flame can spread throughout the house through the open trusses. They put a reasonable limitation on the size of that cavity and also require that the space be divided somewhat evenly.
Same Old is offline
Old 03-12-2007, 05:08 PM   #11
Same Old's Avatar
Rewards Points: 250
what?
Same Old is offline
Old 03-12-2007, 05:09 PM   #12
Same Old's Avatar
Rewards Points: 250
That's "fireblocking"
Same Old is offline
Old 03-14-2007, 03:09 PM   #13
Tom M's Avatar
Sec 717.3.1 2006 IBC Draftstop materials--- drywall is the cheapest--use scrap out of the dumpster
Tom M is offline
How well do waxed floors hold up? d-rez Flooring 2 06-16-2007 04:35 PM
Epoxy garage floors gschwoyer Painting & Finish Work 3 02-23-2007 08:36 AM
Painting wood floors steve-in-kville Painting & Finish Work 6 12-25-2006 08:28 AM
Refinishing pre-finished v-grove floors Bob H Flooring 3 09-29-2006 07:07 AM
Stop paint from chipping/latex over oil pdxhandyman Painting & Finish Work 4 06-27-2006 05:32 PM
