Trade: EXTERIORS
Decks
What do you guys think about this
100 decks total 24 12 X 10 24 12 X 16 52 10 X 10 Half of them are second story Could any of you do these all for $5 per square ft.? |
Insert title
Trade: Doors-Windows-Decks
Re: Decks
Stainless steel hangers, bolts, and screws cost about $5.00 psf.
Framing material, post and concrete also cost around $5.00psf. Decking is a little more than $5.00 psf (composite). El-cheapo railings $5.00 psf. The cheapest labor that I've ever seen is 12 psf. Not being a wise ass but I figure everything by the square foot and those are my prices without profit and overhead.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
Trade: EXTERIORS
Re: Decks
im getting a little confused with your numbers. What would you tell the customer per sq ft?
Insert title
Re: Decks
My material prices are $25.00 cost (investment grade materials not home center crap).
My labor cost is $12-$15 psf. Add those two figures together and your at close to $40.00 psf then add your overhead cost and figure how much profit you want to make. In my area you can have a deck built for $35-$40 psf with the cheap stuff and by people that do not charge for profit and overhead.
Rebuilding the past.
Trade: Remodeling , renovations , snow services
Re: Decks
Im generally around $20 psf for PT decks. That is for ground decks. There are add ons to this too. A lot of towns require weed barrier and stone under decks.. 2nd floor decks would be a little more depending on conditions. You couldnt afford the material to build it at $5 psf.
Interoir and Exterior Home Remodeling and Snow Services
Midwest BuildIt Inc. |
#6 | |
Insert title
Re: DecksQuote:
- permits -digging for footings -faming material -all fastners -railings -dumpster for clean up/haul away -stairs -removing siding, flashing the deck and replacing siding -site clean up/ reseed lawn around deck The prices must be a little better out in your area! I use to make 15 psf labor only 9-10 years ago, at the time the deck packages were 30 psf.
Trade: EXTERIORS
Re: Decks
I told the guys $20 per sq. ft. He hung up on me and then called me back 1 hour later. He said he had a bid of $5.25 per sq. ft. and I was thinking "I could not do it for that with a crew of "cheap labor" for that" price. I posted it on here to confirm that he was talking out his ass no one could do it for $5 per sq ft.
Insert title
Re: Decks
He must be confusing $5.00 and $50.00, a common problem with crack heads. The only thing I can figure is $5.00 psf for labor which is sort of low.
Dream Maker
Trade: residential construction
Re: Decks
i can frame a 10x10 and picture frame deck it. flash it to house. no rails no stairs in a day. and work at a casual pace. that'd be $500. 2 guys. I think id rather get $6 sq ft. instead.
Dream Maker
Re: Decks
ya labor
Trade: EXTERIORS
Re: Decks
Im trying to figure out a fair bid on this job for the hell of it.
how long do you guys think it will take 2 workers to build a second story 10 x 10 with railings?? |
Trade: Custom deck builder
Re: Decks
Naw... I would be looking for $8 SQ FT. MIN for labor only and that is only on the ground level for a face screwed PT/RDWD/CEDAR with the most basic of rails and no steps. Without having to deal with permiting and ordering of materials. Just pull up and build the deck for that price. And that price wont last if the materials are shorted and I have to wait.
#13 | |
Trade: EXTERIORS
Re: DecksQuote:
Re: Decks
10-12 depending upon how high it really is on the low point. In other words am I going to have to cary EVERY piece of lumber up a ladder for the entire project. Or is 1 end low enough that I can lean up the lumber till I get up on the framing.
#15 | |
Re: DecksQuote:
Now if your talkin a fancy multi level trex deck. Im probably at about $45 to $70 psf depending on railing design/material and if theres curves or not.
#16 | |
Trade: Decking, Fencing and Remodeling
Re: DecksQuote:
If you have to tear out and fix other peoples stuff, or provide materials etc, than no way. 12,000+ sqft would actually go pretty quick if you could replicate each deck over and over. |
Home Repair Specialist.co
Trade: carpentry
Re: Decks
A 10x10=500,00 a 12x10=600,00 a 12x16=960,00 I dont see how you would make any thing but wages on this and that would be low wages be caeful you could loose your ass on this one and if they are upper decks even worse a 10x10 bottom deck with 3 guys footings gurders joist decking hand rail screw off clean up. lucky to do that in a day and if you diden't you have all ready lost money.But if you do get the job for a good price then set up a cut yard and pre cut every thing into packages for each deck two guys cutting two guys putting them together and one good labor
| Pool Decks | Patton | Painting & Finish Work | 1 | 05-14-2007 09:52 PM |
| Decks | birdog | Painting & Finish Work | 1 | 02-24-2007 01:32 AM |
| Decks | DGirlando | Carpentry | 0 | 07-21-2006 06:53 PM |
| Decks & Fencing moved to Carpentry Forum | Nathan | Decks & Fencing | 0 | 04-14-2006 09:02 PM |
