Cultured Marble Counter Top
Old 11-06-2007, 10:32 AM   #1
ponch37300's Avatar
Trade: general contractor
i am installing a vanity in a bathroom with a cultured marble counter top that needs to be scribed to the wall. What is the best way to do this? can i use a belt sander? Thanks for any help on this one, i have never worked with this material before.
ponch37300 is offline
Old 11-06-2007, 12:12 PM   #2
MFWIC
Tmrrptr's Avatar
Trade: house painter
Re: Cultured Marble Counter Top
Sure, coarse belt on sander... or use a right angle grinder...
r
Tmrrptr is offline
Old 11-06-2007, 12:19 PM   #3
send_it_all's Avatar
It machines with regular woodworking tools. I cut cultured marble all the time with a carbide tipped blade in my circular saw.
send_it_all is offline
Old 11-06-2007, 12:32 PM   #4
ponch37300's Avatar
thanks for the quick replies guys. i appreciate it.
Old 11-06-2007, 10:20 PM   #5
Trimwerx's Avatar
Its just like working with fibreglass products
Trimwerx is offline
Old 11-07-2007, 10:21 PM   #6
troubleseeker's Avatar
True, but he is probably safer to work to a scribe with a belt or disk sander, as there is less chance of the back edge of the blade causing a chip in the gel coat. If the wall is that bad that the thickness of the splash won't cover the gap, it is not going to be easy to make the splash look good against the wall without a big caulking gap somewhere, some mud work may be in order here.
troubleseeker is offline
Old 11-08-2007, 10:28 PM   #7
ponch37300's Avatar
just wanted to say thanks again guys. The counter top is in a corner that isn't perfectly square so i had to scribe the side of the countertop. Did it just like wood countertop, scribed line and used belt sander. Turned out perfect! Thanks again for sharing your knowledge with me on material i never used before.
cultured marble repair shelf guy General Discussion 3 08-16-2007 04:55 PM
Tiling over Marble??? RussellF Ceramic & Stone Tile 5 01-27-2007 08:12 PM
White Marble Stained and needs Cleaned ABLE1 Masonry 4 07-31-2006 10:34 PM
Cutting cultured marble kenvest Plumbing 16 11-23-2005 09:54 PM
help removing cultured marble around baht tub izote61 Construction 1 07-23-2005 10:12 AM
