Cheaper Alternatives To Tempered Glass?
Old 02-03-2011, 09:22 AM   #1
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
Hey there.
Just wondering if there is a cheaper alternative to tempered glass. I'm specking out a railing for a loft space and don't want to blow the budget. It's a fairly rough space so I don't think a tempered glass sparkle is necessary. I'm looking for something cheaper than 1500-2k for the glass panels.
Is there an acrylic/plexi glass that would be close to tempered glass, and still look decent? Yes it might be more scratch resistant, but I want to present both options to HO.
Thanks!
Mike
sbcontracting is offline
Old 02-03-2011, 09:30 AM   #2
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Re: Cheaper Alternatives To Tempered Glass?
There are films that can be applied to glass that will allow it to pass code. They will vary in how they look. A good glass company can give you some options.
Mike Finley is offline
Old 02-03-2011, 09:41 AM   #3
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Lightbulb
3/16" glass is an alternative. Stonger but breaks into large deadly pieces.
Depending on the size, Lexan would be a good, cheaper alternate.
skyhook is offline
Old 02-03-2011, 10:21 AM   #4
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
That seems a little excessive. I pay about $70 for a 48" x 42" tempered glass panel for deck railings. How big is the railing? 200 feet?
Get them at Home Hardware:
http://www.homehardware.ca/en/rec/in...tt=Regal+Ideas
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
The Following User Says Thank You to Chris G For This Useful Post:
sbcontracting (02-03-2011)
Old 02-03-2011, 06:52 PM   #5
Rewards Points: 562
I'm still waiting on a quote from a local glass provider - but was given the impression that it would be around $1500. The railing is 32" on the short side and 96" on the long side. I'll definitely check out ham hardwire!
Old 02-03-2011, 06:59 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 8,948
Lexan isn't exactly cheap, but would work. Forget about plexiglass. And if you do go with glass I wouldnt use anything but tempered.
Morning Wood is online now
Old 02-04-2011, 09:56 PM   #7
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
Tempered is all over the place, some shops are 5$ a sqf some are 50$ a sqf, find a good fair glass company and make them your best friend.
As a reference I can get them cut polished and drilled for railings under 100 a piece.
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
The Following User Says Thank You to Scribbles For This Useful Post:
sbcontracting (02-05-2011)
Old 02-04-2011, 11:02 PM   #8
Gonna die a glass guy
ccappaul's Avatar
Trade: Skylights and Glazing
Rewards Points: 250
Hmmm...... something must be missing here .....
That price sounds like a tempered 3/8 or even 1/2" with edge work, hardware and installation.
You could use 1/4 tempered in a wood railing for perimeter leave out the edgework and the cost should be less than $150.00
NON Tempered Absolutely NOT.
And any glass like alternatives should not be used. Lexan or plexi will scratch up and the money spent will be wasted.
Was Hamhardwire? stainless cable ? that would look classy but probably still gonna be a couple bucks
ccappaul is offline
Old 02-05-2011, 12:31 AM   #9
Deck Designer/Builder
DecksEtc's Avatar
Is that just one piece that you need?
My glass supplier is roughly $7/sq. ft. for 1/4" tempered glass panels.
Note to ccappaul, Chris is referring to Home Hardware - a local chain of suppliers here in Canada
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
The Following User Says Thank You to DecksEtc For This Useful Post:
Old 02-05-2011, 07:59 AM   #10
Rewards Points: 562
Home Hardware == Ham Hardwire.
We also have "Crappy Tire" aka Canadian Tire.
Old 02-05-2011, 08:15 AM   #11
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Personally, I would use laminated safety glass for a railing.
Basically, it's windshield glass.
I used it in my own home. The benefit is, even if broken, the panel will remain in place, adding a safety feature that tempered glass doesn't have.
The other thing is, if broken, the clean-up is much easier, as it will remain in one piece.
I did this project in 2000. I made plywood templates for the panels. They were under 1K dollars, complete.
Cheaper Alternatives to Tempered Glass?-030-2-1.jpg   Cheaper Alternatives to Tempered Glass?-047.jpg   Cheaper Alternatives to Tempered Glass?-012-3-.jpg
loneframer is offline
Old 10-18-2015, 12:38 PM   #12
Breshape's Avatar
Trade: Residential
You can buy a 6 foot tempered glass patio door for under $225. Remove the aluminum frame, take a razor knife and split the panels apart and you have 4 sheets at a reasonable price. I have done this several times its really not hard to do.
Breshape is offline
Old 10-18-2015, 01:18 PM   #13
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Building Contractor
Rewards Points: 1,380
Once you have four panels of glass, how the heck do you cut them down to size?
Builders Inc. is offline
Old 10-18-2015, 01:36 PM   #14
Breshape's Avatar
Trade: Residential
You can't cut them. They will be 34" x 78 " approx. depending on the manufacturer.
Breshape is offline
Old 10-18-2015, 04:48 PM   #15
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,118
I trust he has done something about this in the four years since he first posted.
Andy.
ScipioAfricanus is offline
Tempered Glass? Mitch M Windows, Siding and Doors 8 10-24-2010 03:31 PM
Tempered glass question davinci Windows, Siding and Doors 8 07-22-2010 07:37 PM
Tempered Glass Repairs NAV Sandblasting 18 12-01-2009 01:57 PM
Cutting Tempered glass - anybody successful with this? ksskss Tiling 3 10-05-2009 03:47 AM
tempered glass, read genecarp General Discussion 5 04-02-2008 09:21 PM
