Trade: Site work, underground utilities, estimating & layout
Changing A Table Saw Blade
Probably silly question....I was given an older Craftsman table saw. The blade is spent. I went to take it off the other day and ran into a problem. When I try to turn the nut the shaft spins. I was looking for a way to put a wrench on the shaft or maybe a lever or button to hold down to keep it from spinning as I loosen the nut. Didn't see anything. Am I missing something obvious?
Trade: Custom deck builder
Re: Changing A Table Saw Blade
Holding the blade might work. That is the way a lot of older ones did it.
I put a screwdriver through the little hole on the blade so it wouldn't spin as I tried to turn the nut. So, the blade stood still and turning the nut makes the shaft spin. Any other thoughts?
Thanks, Mike |
Set the saw on a piece of wood also, then put a bit of sideways pressure on the blade so it can bind the shaft.
Frank Slate Roof Repairs, Richmond, Va. |
Trade: Squirrel Handler
Hold the blade, left hand threads.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Thanks Tinner666, I will try that.
Mickey - The blade is being held in place as I apply pressure to the nut. In either direction the shaft spins with the nut....driving me crazy....maybe I should try my sledge hammer
Pneumatic Impact wrench worked for me on a particularly old stubborn table saw.
Also is there a slot in the end of the shaft (opposite end of shaft than the blade) you can put a large screwdriver blade into? |
Mod / ArchiBuilder
I hope you have it unplugged?
You can never be too safe!
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
I vote impact wrench.
I vote a 14 lbder and a trip to the tool store.
Trade: Carpentry/ Framing
A little WD-40 or some other penetrant oil probably wouldnt hurt either.
Al Smith
look behind the blade and see if there are two flats on the arbor. Some of the older saws use a proprietary two wrench set for changing blades..
I've got two old Craftsman saws and both of them are two wrench deals.
Is it possible that someone put a diamond arbor blade on there? Either way, you need some way to get a grip on your arbor. (Never thought I'd say that to another guy!) ![]() ![]()
There was a little over an inch of shaft on the side of the blade away from the motor. I ended up putting two nuts on that and tightening them to each other. Then put a wrench on that inside nut and a wrench on the nut was trying to remove. Pulled opposite directions and she came loose for me.
![]() Victory was mine........Drank 3 beers...had a cigar Actually, the beer and cigar was going to happen even if I failed. |
| Blade Wobble New Miter Saw | balanceact | Finish Carpentry | 7 | 06-03-2008 09:12 AM |
| Leeson table saw motor | Milhaus | Electrical | 6 | 10-14-2007 08:24 PM |
| So what diamond blade DO you use? | lukachuki | Masonry | 15 | 01-03-2007 01:24 PM |
| Router table | magnum | Tools & Equipment | 14 | 01-01-2006 12:52 AM |
| Very small/thin table saw blade | Woodcrafter74 | Tools & Equipment | 25 | 12-28-2005 07:25 AM |
