Cedar Siding
Old 05-27-2004, 09:45 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Cedar Siding
In the chicago area what would a fair price be for labor to install cedar siding? Its a brand new home. no tearoff involved.
Old 05-27-2004, 10:48 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Cedar Siding
Wow I am in the chicago area
I don't have my spreadsheet with me so expect an answer tomorrow. Can you give me more details on type of siding and approximate size (squares)? Also is fascia and soffit included or seperate? Do you want bare, preprimed or pre-stained?
I recommend pre-stained so you don't have to paint, and the upgrade is cheaper than hiring a painter.
Grumpy is offline
Old 05-27-2004, 11:12 PM   #3
Unregistered
Guest
Posts: n/a
Re: Cedar Siding
Grumpy I think its pre-stained.Its about 35 squares. I may have to do the soffit and facia.I don't know how many feet yet. Its going to be a 6 inch overlap.Whats the usual price for soffit and facia per ft. ?
Old 05-28-2004, 08:45 AM   #4
Bah Humbug!
Grumpy's Avatar
Re: Cedar Siding
I'd charge around: $425 (labor and material) for the 2 coat prefinished horizontal cedar 6" exposure . I'd charge about $12 per foor of soffit and fascia with a 1' overhang (labor only).
Grumpy is offline
Old 05-28-2004, 08:49 AM   #5
Bah Humbug!
Grumpy's Avatar
Re: Cedar Siding
I should also note, I am usually on the high end when it comes to cedar siding. But I have seen some real junk installed due to rushing the job.
We use combination corner posts, most guys double up 5/4x4. Our method take a bit more time but looks stunning. We caulk the butt joints to delay water penetration. I recently saw a job where not a drop of caulk was used anywhere. Sad really.
Good luck!
Grumpy is offline
Cedar siding removal bid help haskl33 Windows, Siding and Doors 21 07-03-2009 12:55 PM
Help with - Inside corner trim for vertical cedar siding wallmaxx Framing 3 07-22-2007 06:47 PM
OLD unprotected cedar siding DeanV Painting & Finish Work 4 11-13-2006 08:36 PM
Cedar Siding estimate help SOSSW Windows, Siding and Doors 17 04-26-2006 07:50 AM
Cedar siding question? XXL Hardscaper Windows, Siding and Doors 2 01-31-2006 02:50 PM
