BIG D
Trade: Carpenter/Builder/Contractor
Cedar Shake Spacing?
I've seen some guys installing shakes on a house that dont "space" them apart at all.....the whole thing buckled and he had to re-do it. BUT, I've also seen (and installed) shakes tight that have not had that problem. On This Old House, Norm was siding a shed with white cedar shakes (i belive) and he actually planed them with a hand plane so as to be tighter. Anyone have experience with this? Problems or ideas?
remember what you did right, then do it again! |
I like Green things
Re: Cedar Shake Spacing?
I suppose that depends on what is behind the shakes. They are going to need to dry from both sides.
Trade: Residential Construction
I have seen people space them to far and when they shrink they end up with a big gap
#4 | |
BIG D
Re: Cedar Shake Spacing?Quote:
Right, me too. I'm wondering if it depends on the shake as well...Like you said, how dry it is before you put it up and what kind of vapor barrier it is behind. I felt bad for the guy who had to re-do all that! About 30 squre. It was a mess.
Al Smith
Shakes that are not primed and are directly exposed unprotected to the weather get spaced, Shakes that are dried and primed and painted do not get spaced.
http://www.cedarbureau.org/installat...ual/page12.htm Last edited by A W Smith; 01-31-2009 at 02:43 PM. |
| The Following User Says Thank You to A W Smith For This Useful Post: | ribuilder (01-31-2009) |
Trade: General Contracting
It depends on the moisture content of the shingle. If they are bone dry they are going to swell and need to be spaced. I have wet them down because it's easier for the help to lay them touching than leave a consistent 3/16 gap.
| The Following User Says Thank You to dubz For This Useful Post: | ribuilder (01-31-2009) |
#7 | |
BIG D
Thanks for link Al. We did some homes when I lived in NY over in Nyack, alot of old victorians, I noticed some were spaced and some werent, some as much as 1/4". As that manufacturer says, 1/8 to 1/4. Makes sense. I've never spaced the primed ones either. Well ....thanks!
Trade: siding
How i was taught is the striated are butted all others are spaced .The spacing not only allows for swelling it also allows you to keep the shingles plumb without having to plane them.Every box of shingles i ever saw whether primed or clear say to gap
cedar shingles are usually stored inside until delivery so they are relatively dry but they swell when they get wet you can even see on those vinyshake panels they are always spaced Al i dont see in that link where it says to butt if primed Last edited by Tom Struble; 08-06-2010 at 09:07 PM. |
| Cedar shake roofs. | HallisseyDesign | Roofing | 11 | 04-10-2009 06:32 PM |
| Cedar Shake Exterior: Paint v. Stain | jen_o | Painting & Finish Work | 3 | 06-24-2008 05:27 AM |
| clean up old cedar shake | asphaltroofing | Roofing | 8 | 05-13-2008 10:27 PM |
| Cedar Shake Help | TurnkeyConst | Roofing | 13 | 12-28-2007 12:21 PM |
| Looking for Roofer in greensboro nc for estimate on cedar shake | TurnkeyConst | Help Wanted or Looking For Work | 1 | 12-17-2007 07:48 PM |
