Can You Name These Fireplace Trim Parts?
Old 09-09-2009, 04:39 PM   #21
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Can You Name These Fireplace Trim Parts?
Shoot there are enough big words in that cheat sheet for me to retire on. I might just make it my mission in life to try to figure out how to work the word 'spandrel' into a sentence.
Mike Finley is offline
Old 09-09-2009, 04:59 PM   #22
Jeremy E's Avatar
Trade: carpentry
"That little cocker spandrel just peed on the pilaster."
Jeremy E is offline
Old 09-10-2009, 12:56 PM   #23
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
The greatest thing is, that website is nothing more then an advertisement for a company.
TBFGhost is offline
Old 09-15-2009, 07:52 PM   #24
Martin Co's Avatar
Originally Posted by TBFGhost View Post
Good one, I booked marked this page!
Martin Co is offline
Old 09-15-2009, 09:29 PM   #25
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Fireplace glossary:
Capital moulding - the decorative detail drawn from the classical orders with sits at the head of pilaster or column.
Chimneypiece - the fire surround or mantelpiece.
Contre coeur - a set of three decorative cast iron panels with sit with chimneypiece framing the fire chamber.
Corner blocking - the decorative panel found at the head of a jamb.
Corniced mantel shelf - a mantel shelf incorporates a series of architectural mouldings.
Detached column - a column thet stands free of the jamb of the chimneypiece.
Engaged column - a column that is attached yo the jamb of the chimneypiece.
Entableture - the term to describe the frieze, corner blockings and mantel shelf as one unit.
Fire basket - free standing grate which houses a fire and sits within the fire chamber.
Fire dogs and andirons - decorative supports for the fire basket.
Frieze - the cross member between the jabs of a chimneypiece.
Frieze tablet - the decorative panel found at the center of the frieze.
Header and slips - non combustible panels set between the chimneypiece and fire chamber to protect the former from the heat of the fire and ensure a fire that draws safety.
Hearthstone - the non conbustible base upon which the chimneypiece sits.
Ingrounds - facing slips that form part of the chimneypiece and with frame the opening.
Jambs or pilaster - the vertical sections or "legs".
Plinth block - the supporting base to the jamb.
Register grate - decorative steel or cast iron unit housing the fire which conceals the brick fire chamber.
Maybe that helps too.
Resta is offline
Old 09-16-2009, 10:40 PM   #26
Tom R's Avatar
That is how I have always seen the architrave....so to me in order to be an architrave it has to rest on top of the columns/pilasters/piers....
That is the most common definition indeed, - - but, like many other words in the english language, also has other meanings. Here for instance, is the very first definition I googled (bold print my own) . . .
ar·chi·trave (ärk-trv)
n.
1. The lowermost part of an entablature in classical architecture that rests directly on top of a column. Also called epistyle.
2. The molding around a door or window.
http://www.thefreedictionary.com/architraves
(I don't have time to look further right now, - - but believe me, - - it's also the molding around an 'opening')
http://www.tr-built.com
Tom R is offline
Old 09-16-2009, 10:47 PM   #27
Tom R's Avatar
Here's another . . .
Architrave
architrave (?), n. (F. architrave,fr. It. architrave; pref. archi- + trave beam, L. trabs.) (Arch.) (a) The lower division of an entablature, or that part which rests immediately on the column, esp. in classical architecture. See Column. (b) The group of moldings, or other architectural member, above and on both sides of a door or other opening, especially if square in form.
http://knowledgerush.com/kr/encyclopedia/Architrave/
Tom R is offline
Old 09-16-2009, 10:53 PM   #28
Tom R's Avatar
In fact, here's a pictured (fireplace) architrave . . .
(it's on page 5 here) . . .
http://www.lexic.us/definition-of/architrave
Tom R is offline
Old 09-18-2009, 01:05 AM   #29
Moderator
Double-A's Avatar
A = Ching
B = Cha
C = A+B or Cha Ching
D = Bling
E = Bling
therefore, C+D+E= Bling Bling ChaChing... or in the words of Jessy James, "Pay up Sucker".
And BTW, I don't care what Tom'R says, I agree with him.
New York Times, July 20, 2006
Double-A is offline
Old 09-18-2009, 11:10 PM   #30
TBFGhost's Avatar
Architrave
These are all correct answers, but I find myself sticking to where it all began. From some reason I just find it wierd calleding the whole set-up an Architrave. It only makes sense in my mind to be the part that rests on the columns or pilasters...
TBFGhost is offline
Heating new Family Room w/ gas fireplace? Slowtrawl HVAC 56 06-20-2010 06:50 AM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 06:43 AM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
