Brick Veneer Chimney W/ Factory Insert
Old 09-13-2006, 09:50 PM   #1
rhomfeld's Avatar
I have a code inspector that is giving me fits. I installed a 42" gas/wood burning fireplace instead of a true masonry fireplace. I framed the flue through the rough and boxed in around the metal flue for the chimney. Now I want to brick the chimney. I installed triple green rafters next to the chimney to support the brick weight.
Is this common practice for you all? How do you frame for a brick veneer or stone chimney when not using a masonry fireplace?
Thanks,
Roy
rhomfeld is offline
Old 09-13-2006, 10:03 PM   #2
Tscarborough's Avatar
Re: Brick Veneer Chimney W/ Factory Insert
Use Faux Brick. Otherwise, the masonry has to be carried from the slab.
Tscarborough is offline
Old 09-13-2006, 10:56 PM   #3
mdshunk's Avatar
Exterior masonry veneers with a weight of less than 40 pounds per square foot are permitted to be supported by wood or steel (R703.7.2). The chimney's veneer will surely have a compressive weight of more than that.
mdshunk is offline
Old 09-14-2006, 12:30 AM   #4
rhomfeld's Avatar
I see brick chimneys everywhere and know they do not have full masonry fireplaces. I have visited with several contractors that build million dollar homes and they say use triple greens. Engineering wise, triple greens (2x6's) are more than strong enough to support 120 lbs/lf with a deflection of less than L/240.
I am not for sure I agree with your comment...
rhomfeld is offline
Old 09-14-2006, 12:56 AM   #5
rhomfeld's Avatar
Checked the code again... and I read the section you stated, 703.7.2 and found where three triples are good enough. King size brick with mortar is around 30lbs/sqft. Figure 703.7.2.2 shows how to install it. I will settle this with the inspector in the morning.
Thanks for getting me in the right direction mdshunk.
rhomfeld is offline
Old 09-15-2006, 09:20 PM   #6
I am too focused on full masonry chimneys, sorry. I get a calculation of 4-10 PSF bearing weight max, which is easily covered by your design.
Old 09-15-2006, 09:23 PM   #7
mdshunk's Avatar
Sooooo.....
How did you make out with the inspector?
mdshunk is offline
Brick veneer vs solid masonry sean mccormack Masonry 16 04-23-2011 05:15 PM
brick veneer? sandyman720 Masonry 6 05-02-2008 04:32 PM
Brick Veneer support over large opening. Atlantex Masonry 8 08-14-2007 12:02 AM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 05:20 AM
Direct vent fireplace into brick wood burning chimney? rach0990 Masonry 3 05-25-2006 07:20 AM
