Boxing Out Corners On A Garage
Old 06-23-2006, 10:12 PM   #1
digger00's Avatar
Trade: Garage Builder
I'm still trying different ways of doing it. Does some have the easy way when building a garage to box out corners of the garage???
digger00 is offline
Old 06-24-2006, 12:21 AM   #2
jmic's Avatar
Re: Boxing Out Corners On A Garage
Might be a regional term, but what do you mean "box out corner"?
Joe
jmic is offline
Old 06-24-2006, 10:11 AM   #3
Tom R's Avatar
Thanks, Joe, - - that's what I was trying to figure out . . .
Digger??
Tom R is online now
Old 06-24-2006, 11:06 AM   #4
Gaetano
vtgaetano's Avatar
Send a message via Yahoo to vtgaetano
I think he means UFC octagon?
"Quality is not expensive, it's priceless"
vtgaetano is offline
Old 06-24-2006, 11:18 AM   #5
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
He's probably talking about bird boxes.
Dave.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 06-24-2006, 11:37 AM   #6
Gaetano
vtgaetano's Avatar
Dave.
Like "returns"???????? Pigeon stoops, that kind of thing?
Old 06-24-2006, 12:16 PM   #7
joasis's Avatar
I was guessing plywood on the outside corners...a lot of builders here used to do this. Haven't heard it called that or anything close though.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 06-24-2006, 01:38 PM   #8
digger00's Avatar
Ok, I guess I am not using the right term. On the corners where the two overhangs meet. It looks like a box to me so maybe that is a bad term to use. Is there a proper term, and any suggestions of a easier way to build them??? I'mnot sure how to better explain it.
digger00 is offline
Old 06-24-2006, 04:57 PM   #9
jmic's Avatar
Ok, I call them returns. I know someone who calls them pork chops ( how do you figure?)
Joe
jmic is offline
Old 06-24-2006, 05:09 PM   #10
Tom R's Avatar
Hey, that's what I always called them . . .
(kind of got that triangular shape like a pork chop)
Actually, - - I call it a 'return' if it's 'boxed out' (has some depth) . . .
I call it a 'pork chop' if it's flat (like just 3/4" thick)
Tom R is online now
Old 06-24-2006, 06:12 PM   #11
extreme birdhouse builder
cranbrook2's Avatar
Trade: framing ,trim ,roofing,fences and decks .
Gable returns
cranbrook2 is offline
Old 06-24-2006, 06:29 PM   #12
Tom R's Avatar
Originally Posted by cranbrook2
Gable returns
Alright, - - if we're gonna go technical, - - I'll go (closed) 'CORNICE'!!
Tom R is online now
Old 06-24-2006, 07:22 PM   #13
jmic's Avatar
Digger,
Now that we've established what you're talking about I suppose you'de still like an answer. Sort of hard to explain, for a boxed look, I'd level back from the bottom of the facia and maybe just go back a little beyond the corner board if in fact you're using them. Depending what you're using for trim, ( lets suppose you're using 2x sub material and wraping with aluminum). Cut your angle pcs. ( inner and outer ) nail them to bottom of barge rafters, then I always close the end with a pc. of plywood. After you wrap all your trim then you can run your cornerboard right up under it. Hope this is of some help. Now I'll turn the floor over to someone else to explain a different style, perhaps wraping the roof around. Anyone?
Joe
jmic is offline
Old 06-24-2006, 07:31 PM   #14
Tom R's Avatar
Just seems too hard to explain, - - there are SO many different styles of cornice returns . . . then, like you say, with some, the roof returns, too . . .
Then the 'finish material' makes a difference on whether it needs to be built 'solid' or not . . .
Anyone wanna give it a try??
How are you doing it now, digger??
Tom R is online now
Old 06-24-2006, 08:21 PM   #15
digger00's Avatar
Ok thanks guys for setting me straight on the proper term. Talk about hard to explain you will be saying what the hell after this. I guess I'm doing it like JMIC said with cutting plywood in a triangle and then running a 2x6 from the front of the garage to give it that "boxed look" to make it easy to wrap it with soffit and facia. If you have any other suggestions keep them coming.
digger00 is offline
Old 06-25-2006, 09:33 AM   #16
specwood's Avatar
We call them "wing dings". Not a common term at all unless you have worked for me. Usually we can get them from a scrap 2x8 or 2x10.
specwood is offline
Old 06-25-2006, 10:51 AM   #17
Tom R's Avatar
Originally Posted by specwood
Attachment 2378
OK, - - 'wing dings' it is, then!!
Good Pic . . .
Tom R is online now
Old 06-25-2006, 02:14 PM   #18
digger00's Avatar
Great picture specwood!!! That is pretty much what I've been doing except the piece of wood attached to the garage is right on the corner.
Thanks for everyones help!!!
digger00 is offline
Old 06-25-2006, 02:20 PM   #19
unlicensed hack
maj's Avatar
Trade: wood butcher
I don't care for the boxed out look myself. More & more of us around here are doing it different......
In the picture..... take the triangle shaped piece and move it back flush to the rake side wall. This eliminates the need for the rectangular shaped piece. This way there is no "box" look. The rake side soffit goes all the way down to the eaves subfascia. Siding then covers the triangle shaped piece. Maybe I need to post a pic for you to understand, or maybe you get it????
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 06-25-2006, 02:24 PM   #20
Tom R's Avatar
Yeah, spec's way (off-set) is much better than 'dying-in' to the corner (jmic had mentioned that, too) . . .
Looks much better and leaves a 'home' for the top of your corner posts to end squarely.
Tom R is online now
Garage receptacle ChuckEA Electrical 21 04-27-2011 07:45 PM
garage insulation maderuyck HVAC 2 03-18-2007 12:43 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
...continued...garage floor drain progress carlspackler Plumbing 0 05-27-2006 02:54 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
