#21 |
Trade: master electrician
Re: Bouncy Floors
Where exactly do I nail these strong backs? I've heard them being nailed to the webs - what part of the truss does that indicate - I have an idea, but I'd rather be sure of what I'm doing... Again please forgive my ignorance on the subject, the most carpentry work I do is drill holes in the studs for all my wiring.
" I put the holes in. " |
#22 |
Re: Bouncy Floors
It would be easier to know
what you've got if you can post pix. We are really just guessing what your problem is. Can you do that?
#23 |
Trade: framing/remodeling
Re: Bouncy Floors
If you have what we refer to as truss joists they are made up of 2x4's and metal gusset plates. If yours are made of osb with a 2x top and bottom we call those TJI's. if u have the truss joists, the stiffbacks are nailed to a vertical 2x4 member perpendicular to the joists. Generally all the joists will be oriented the same way so that these webs line up.
#24 |
KemoSabe
Re: Bouncy Floors
If bridging is installed properly, it is essentially the equivelent of building another truss perpendicular to the trusses. The more rows of bridging, the more trusses you are building to distribute load. Think about this, How much weight can you hang from a swingset? If you remove two legs it collapses. Bridging serves the same purpose, distributing load evenly.
#25 |
Trade: custom home building
Re: Bouncy Floors
Greenley,
Was the floor bouncy when the sheetrock was stocked? |
#26 |
Re: Bouncy Floors
No pics -sorry - I don't have the tech-skills...
The truss system is made up of of 2x4's with metal gusset plates. Don't know if the floor was bouncy when the Sheetrock was stocked. I think I'm back to the bridging idea now - I do have a good number of metal plates that span between each truss - would those be sufficient bridging?
#27 |
Re: Bouncy Floors
Are they maybe more like
metal straps? Do they make "X's" between the truss?
#28 |
KemoSabe
Re: Bouncy Floors
If you have metal bridging and it doesn't "ring" when you pluck it, you will get bounce in your floor. If you do wood bridging properly with clean cuts and tight installation you will definitely see a vast improvement. That is a promise.
#29 |
Re: Bouncy Floors
The metal plates do not make an "x". They span from truss to truss and have tabs at each end for nailing to the wood.
#30 |
Re: Bouncy Floors
Do you have a friend who can
take pix and e-mail or load them to your computer? One pic looking down the joist bay would save lots of guesses.......
#31 |
KemoSabe
Re: Bouncy Floors |
#32 |
Re: Bouncy Floors
Does it look like this stuff?
http://www.theracker.com/products.htm
#33 |
Re: Bouncy Floors
Greenley,
Put a piano or a bunch of buckets of water in the center of the span and see if it helps. I've never seen a bouncy floor on the day when the sheetrock was stocked. |
#34 | |
Instructor, ex-contractor
Trade: Construction trades Instructor
Re: Bouncy FloorsQuote:
| Wood floors in an elevated bay house (Texas) | Monarchy | Flooring | 22 | 01-30-2010 12:01 PM |
| Damaged wood floors | anthonyadam13 | Flooring | 11 | 02-15-2009 08:43 AM |
| Refinish Hardwood Floors... What's with the spots?!? (pics attached) | danimal | Flooring | 12 | 02-14-2009 02:50 PM |
| Masking floors for texturing? | Tradesman | Drywall | 14 | 10-12-2008 07:35 AM |
| Epoxy Garage Floors | RoSSco | Painting & Finish Work | 8 | 09-04-2008 11:00 AM |
