Trade: master electrician
Bouncy Floors
I recently built my own house operating as owner-builder. I'm an electrician by trade, so please forgive my ignorance in advance... We used trusses for the floors and they span 22' while being spaced 19" on center. It seems like my floors bounce more than any other house I've been in, and I've been in a lot. The kitchen cabinets shake, and all these heel-walkers (my wife and kids) sound and feel like a stampede going by. Are there any easy fixes or ideas for getting rid of the bounce???
" I put the holes in. " |
#2 | |
Re: Bouncy FloorsQuote:
properly sized, I would have two rows of bridging for that span.
Re: Bouncy Floors
Need more input... remember I'm an electrician, so I need answers in layman's terms...
#4 | |
and pix. Specifics will help get specific answers. Bridging on truss joist would probably look like "X's" between the joist. Meantime Google bridging.
Trade: Home Remodeling
Re: Bouncy Floors
Also, pix of column supports too, if any or lack of??
#6 | |
Instructor, ex-contractor
Trade: Construction trades Instructor
A frustrating problem to be sure. If you go the bridging route, you will improve (lessen) the bounciness, but it will probably still not be acceptable to you. If this is a first floor over a basement area, your best fix may be to install the support girder that you were trying to avoid by using trusses. Another possibility (check with manufacturer) is to plate the sides of the trusses with osb, glued and nailed as per their suggested nailing schedule for such a reinforcement. Make sure your fix does not conflict with their engineering in any way and direct these questions discussed to the truss manufacturer. There is where your safest, surest answers lie. If you used I-joists, there is some possibility of adding material to the web (center vertical) section of the I-joist. Again, refer all these ideas to the manufacturer - don't take our word(s) for the best fix. -Best Wishes. |
Re: Bouncy Floors
The only thing that stops horizontal
defection is bridging. Whether truss, I-joist, or dimensional, The strength is vertical, not horizontal (side to side). If he knew what he was looking for he might be able to see them twist under load. I have. Bridging may not get all the vibration out of a huge membrane, but it will stiffen it and make the joist work as a unit.
#8 | |
Professional Instigator
#9 | |
what little I know comes from fixing other people's ups. ![]()
Grand Rapids Remodeling
Re: Bouncy Floors
I got to diagree. Bridging is not the ONLY THING that stops deflection. I agree bridging is a solution that couldn't hurt without more info. A support truss is another possible solution. The bouncy floored electrician said his kitchen was a problem, not to get down on the plumbing trade but I've seen more than one plumber sawsall a knotch or two in the floor joists.
KemoSabe
Re: Bouncy Floors
I agree with the double row of criss-cross bridging. I would use 1x3 or 1x4 clear pine. Before installing look for sag in the joist, if there is,according to whats above you may be able to take some of the deflection out.Don't attempt this if there are tile floors or cabinets above, only if its open space.Otherwise I would spread the rows of bridging 2 feet each side of centerline of span,keeping them in a continuous line the entire width of the building, this should help tremendously. You may still feel a spounginess to the floor which may be due to 19.2 inch centers, the subfloor is probably deflecting between joists. The bridging will help with the bounce because it forces all joists to share concentrated loads.When attaching bridging in this situation I would hold bridging flat against side of truss and fasten top through short point of angle cut, then fold up to contact other joist, tap up to snug it in and fasten securely, being careful not to split.
#12 | ||
kinds of deflection here. The beam deals with one, the bridging another. If he has a 22' span, it needs bridging.
#13 | |
Trade: Carpentry & Remodeling
Do what you would do, as if i won't Do anything after you Did It! |
Re: Bouncy Floors
Fair enough, my bad I jumped over the horizontal part. My other question would be of the code man letting a 22' span with a 19" OC go with no bridging.
Trade: Home Builder
Re: Bouncy Floors
I build with floor trusses, maybe I can help.
22' should be no problem for floor trusses. I've clear spanned 32' with no problems and zero bounce. Granted I had them at 16"oc, but the original plans had them at 24"oc, my point is they will be engineered for your application to work. By me reducing the spacing, I reduced the bounce. Floor trusses don't require "x" bridging, atleast in my state. They do require strongbacks. Continuous 2x6's nailed to the vertical member (inside the trusses) of the floor trusses. So from truss to truss and so on, from one end of the house to the other a 2x6 nailed to the vertical member with a minimum of (3) 16d sinkers on each vertical. Check the paperwork that came with the trusses, there is usually an explanation and some graphics of what they want and what is required. Now, on my larger spans I increase the the strongbacks to every 5', which is every vertical member in the truss. I'm told by engineering that will decrease deflection. And it does. I've noticed that any bounce or deflection to be almost completely gone when I add that many. The real trick is to not let the other trades notch or cut up those strongbacks. Depending on the height of the trusses, it usually isn't a problem. |
#16 | |
KemoSabe
#17 | |
Trade: Professional Berserker
I think I say OOPS!! out loud way to often. |
#18 |
Trade: custom home building
Re: Bouncy Floors
Original Poster:
Out of curiosity, were the floors bouncy when the house was stocked with sheetrock? |
#19 |
Re: Bouncy Floors
You carpenters are a loquacious bunch - thanks for all the feedback. I think I'll try the strong back idea first, it actually falls within my limited carpentry skills. If that doesn't work, then on to the bridging. In regards to the strong backs, do they need to be nailed to each truss or did I read every five feet? Thank you kind sirs...
#20 |
Trade: framing/remodeling
Re: Bouncy Floors
Strongback needs to be nailed to every truss. Only problem is if the house is done (it is) then you will have trouble getting long lengths of 2x6 inside the webs. We generally slide them in prior to decking before we install our end band board. If you cant wiggle in at least 10 foot sections it probably wont help. Might have to try the bridging and maybe strap the bottom chords with a couple of 2x6 running across the bottoms. This will at least tie them together .
| Wood floors in an elevated bay house (Texas) | Monarchy | Flooring | 22 | 01-30-2010 12:01 PM |
| Damaged wood floors | anthonyadam13 | Flooring | 11 | 02-15-2009 08:43 AM |
| Refinish Hardwood Floors... What's with the spots?!? (pics attached) | danimal | Flooring | 12 | 02-14-2009 02:50 PM |
| Masking floors for texturing? | Tradesman | Drywall | 14 | 10-12-2008 07:35 AM |
| Epoxy Garage Floors | RoSSco | Painting & Finish Work | 8 | 09-04-2008 11:00 AM |
